cgal-discuss - Re: [cgal-discuss] Vertices are not outputting with this point cloud data
  • To:
  • Subject: Re: [cgal-discuss] Vertices are not outputting with this point cloud data
  • Date: Tue, 8 Aug 2017 10:56:54 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
On 08/08/2017 10:36 AM, etaylork wrote:
Hello there,
I have built a program which takes in point cloud data and builds a 3d Model
of the object through delauney triangulation, but am having problems with
one point cloud set data involving these vertices. Every other point cloud
data works, but for some reason I can't get the vertices to show and was
wondering if it had to do the xyz coordinates.
-372 12.3 118
-371 12.3 120
-369 12.3 248
-369 12.3 250
-369 12.3 251
-369 12.3 253
-369 12.3 254
-369 12.3 255
-369 12.3 257
Thank you
I don't know precisely what is your problem but in this case, you have a 2D triangulation. It means that all 3D cells are infinite cells.
But the range of finite vertices should be valid.
If you have some sample code it would help to tell you what can go wrong
with what you did.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Vertices-are-not-outputting-with-this-point-cloud-data-tp4662888.html
