- To:
- Subject: Re: [cgal-discuss] Vertices are not outputting with this point cloud data
- Date: Mon, 21 Aug 2017 00:20:32 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:jix9fx8NAozQNP9uRHKM819IXTAuvvDOBiVQ1KB+1u0cTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV93a95DpXFhTkPhduPcz0HJTThoK5zbOc4ZrWNghUjSu5ZqlxZEG7sQzAss4MgtI8cI4+zxLIpj1DfOEAljAgHk6agxupvpT4x5Vk6SkF4/8=
Hello, Thank you for the reply that was just part of the point cloud data.
The total vertices the file has is 6617. here is the file below, but I am
fairly new to CGAL and cannot figure out why the triangulation_3 demo won't
build or at least show the vertices given from my .OFF file.
Thanks again triangle1.off
<http://cgal-discuss.949826.n4.nabble.com/file/n4662950/triangle1.off>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Vertices-are-not-outputting-with-this-point-cloud-data-tp4662888p4662950.html
- [cgal-discuss] Vertices are not outputting with this point cloud data, etaylork, 08/08/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, Sebastien Loriot (GeometryFactory), 08/08/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, etaylork, 08/09/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, Biswajit Biswas, 08/09/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, Sebastien Loriot (GeometryFactory), 08/17/2017
- Re: [cgal-discuss] Vertices are not outputting with this point cloud data, etaylork, 08/21/2017
