cgal-discuss - Re: [cgal-discuss] Boost is not found when compiling my own code
  • To:
  • Subject: Re: [cgal-discuss] Boost is not found when compiling my own code
  • Date: Tue, 8 Aug 2017 22:10:15 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Ok, I tried to do this, but I get the following result when running it with --trace:
/my/project/CMakeLists.txt(25):  set(Boost_NO_SYSTEM_PATHS TRUE )
/my/project/CMakeLists.txt(26):  set(BOOST_ROOT /my/boost )
/my/project/CMakeLists.txt(27):  find_package(Boost REQUIRED )
/usr/share/cmake/Modules/FindBoost.cmake(163):  if(NOT Boost_NO_BOOST_CMAKE )
/usr/share/cmake/Modules/FindBoost.cmake(166):  if($ENV{Boost_DIR} STREQUAL  )
/usr/share/cmake/Modules/FindBoost.cmake(167):  if(NOT $ENV{BOOST_ROOT} STREQUAL  )
/usr/share/cmake/Modules/FindBoost.cmake(168):  set(ENV{Boost_DIR} $ENV{BOOST_ROOT} )
/usr/share/cmake/Modules/FindBoost.cmake(177):  find_package(Boost QUIET NO_MODULE )
/usr/lib64/boost/BoostConfigVersion.cmake(12):  if(${PACKAGE_FIND_VERSION_MAJOR}.${PACKAGE_FIND_VERSION_MINOR}.${PACKAGE_FIND_VERSION_PATCH} STREQUAL 1.41.0 )
/usr/lib64/boost/BoostConfig.cmake(20):  set(Boost_VERSION 1.41.0 )
/usr/lib64/boost/BoostConfig.cmake(21):  set(Boost_INCLUDE_DIRS /usr/include )
/usr/lib64/boost/BoostConfig.cmake(22):  set(Boost_INCLUDE_DIR /usr/include CACHE FILEPATH Boost include directory )
/usr/lib64/boost/BoostConfig.cmake(24):  set(Boost_LIBRARY_DIRS /usr/lib64 )
This will then again lead to the same error as before.
It seems that cmake absolutely wants to go into /usr/share/cmake/Modules/FindBoost.cmake and then /usr/lib64/boost/BoostConfig.cmake, no matter wheter I set Boost_NO_SYSTEM_PATHS TRUE.
Best regards,
Michael
On Tue, Aug 8, 2017 at 10:00 PM, Chris Marsh <> wrote:
In your project cmake.
And I would not manually set these variables
Boost_DIR /usr/lib64/boost
I would let the find_pacakge call do that for you.
On 8 August 2017 at 13:56, Michael Bieri <> wrote:
Just in the cmake file of my project, or in the cmake file for building CGAL?
On Tue, Aug 8, 2017 at 9:48 PM, Chris Marsh <> wrote:
You put them before the find_package(Boost REQUIRED) call in your cmake file. You will not need to recompile boost.
For example:
set(Boost_NO_SYSTEM_PATHS TRUE)
set(BOOST_ROOT "/my/boost/boost_1_54_0")
message(STATUS "Found boost incl: ${Boost_INCLUDE_DIR}")
message(STATUS "Boost libs to link: ${Boost_LIBRARIES}")
message(STATUS "Found boost lib: ${Boost_LIBRARY_DIRS}")
should print your custom boost library path
On 8 August 2017 at 13:37, Michael Bieri <> wrote:
Hi Chris
Thanks for your answer. Where exactly should I put those lines, and do I need to recompile CGAL afterwards?
Best regards,
Michael
On Tue, Aug 8, 2017 at 9:29 PM, Chris Marsh <> wrote:
When compiling against a custom boost with cmake, you can use this in your cmake file to specify the boost directory
the FindBoost.cmake file will then pickup your custom directory
On 8 August 2017 at 13:14, Michael Bieri <> wrote:
Hello
I'm currently installing CGAL on different platforms. Normally, it works just fine. But I have one computer where Boost is not installed into the system, but just compiled in a directory. This Boost works properly in combination with other things I'm building, just not with CGAL.
I can compile CGAL using the following Boost-related settings, displayed with ccmake:
 Boost_DEBUG OFF
 Boost_INCLUDE_DIR /my/boost/boost_1_54_0
 Boost_LIBRARY_DIR /my/boost/boost_1_54_0/stage/lib
 Boost_SYSTEM_LIBRARY_DEBUG /my/boost/boost_1_54_0/stage/lib
 Boost_SYSTEM_LIBRARY_RELEASE /my/boost/boost_1_54_0/stage/lib
 Boost_THREAD_LIBRARY_DEBUG /my/boost/boost_1_54_0/stage/lib
 Boost_THREAD_LIBRARY_RELEASE /my/boost/boost_1_54_0/stage/lib
 CGAL_Boost_USE_STATIC_LIBS   OFF
Now, I'd like to compile one of my examples. I get the following error:
CMake Error at /usr/lib64/boost/Boost.cmake:536 (message):
  The imported target "boost_date_time-static" references the file
     "/usr/lib64/lib64/libboost_date_time.a"
  but this file does not exist.  Possible reasons include:
  * The file was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and contained
     "/usr/lib64/boost/Boost.cmake"
  but not all the files it references.
The error itself is not a surprise, because it's a very old Boost there.
Boost-related settings for cmake in my project folder are:
Boost_DEBUG OFF
Whe I change the variables to my own Boost in ccmake, it will also throw the above error and not save the changes.
So I really, really wonder: How do I set Boost properly to compile my own code? (I also tried with environment variables as given in the installation manual, Section 15.7.)
Best regards,
Michael
