cgal-discuss - Re: [cgal-discuss] Boost is not found when compiling my own code
  • To: <>
  • Subject: Re: [cgal-discuss] Boost is not found when compiling my own code
  • Date: Tue, 8 Aug 2017 14:22:59 -0600
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
CMake caches a lot of values, and my guess is you're still seeing these cached values. If you place your CMakeLists.txt file (for your project) in a clean folder, does it work?
Alternatively, I use this in a bash script to clean out all the cmake's files to start fresh
#!/bin/bash
CMAKECACHE=`find . -type f  -name "CMakeCache.txt"`
rm -rf $CMAKECACHE
CMAKEFILES=`find . -type d -name "CMakeFiles"`
rm -rf $CMAKEFILES
MAKEFILES=`find . -type f -name "Makefile"`
rm -rf $MAKEFILES
CMAKEINSTALL=`find . -type f -name "cmake_install.cmake"`
rm -rf $CMAKEINSTALL
CMAKETEST=`find .  -type f -name "CTestTestfile.cmake"`
rm -rf $CMAKETEST
Chris Marsh
PhD Candidate
chrismarsh.ca
13 Kirk Hall
University of Saskatchewan
On 8 August 2017 at 14:10, Michael Bieri <> wrote:
Ok, I tried to do this, but I get the following result when running it with --trace:
/my/project/CMakeLists.txt(25):  set(Boost_NO_SYSTEM_PATHS TRUE )
/my/project/CMakeLists.txt(26):  set(BOOST_ROOT /my/boost )
/my/project/CMakeLists.txt(27):  find_package(Boost REQUIRED )
/usr/share/cmake/Modules/FindBoost.cmake(163):  if(NOT Boost_NO_BOOST_CMAKE )
/usr/share/cmake/Modules/FindBoost.cmake(166):  if($ENV{Boost_DIR} STREQUAL  )
/usr/share/cmake/Modules/FindBoost.cmake(167):  if(NOT $ENV{BOOST_ROOT} STREQUAL  )
/usr/share/cmake/Modules/FindBoost.cmake(168):  set(ENV{Boost_DIR} $ENV{BOOST_ROOT} )
/usr/share/cmake/Modules/FindBoost.cmake(177):  find_package(Boost QUIET NO_MODULE )
/usr/lib64/boost/BoostConfigVersion.cmake(12):  if(${PACKAGE_FIND_VERSION_MAJOR}.${PACKAGE_FIND_VERSION_MINOR}.${PACKAGE_FIND_VERSION_PATCH} STREQUAL 1.41.0 )
/usr/lib64/boost/BoostConfig.cmake(20):  set(Boost_VERSION 1.41.0 )
/usr/lib64/boost/BoostConfig.cmake(21):  set(Boost_INCLUDE_DIRS /usr/include )
/usr/lib64/boost/BoostConfig.cmake(22):  set(Boost_INCLUDE_DIR /usr/include CACHE FILEPATH Boost include directory )
/usr/lib64/boost/BoostConfig.cmake(24):  set(Boost_LIBRARY_DIRS /usr/lib64 )
This will then again lead to the same error as before.
It seems that cmake absolutely wants to go into /usr/share/cmake/Modules/FindBoost.cmake and then /usr/lib64/boost/BoostConfig.cmake, no matter wheter I set Boost_NO_SYSTEM_PATHS TRUE.
Best regards,
Michael
On Tue, Aug 8, 2017 at 10:00 PM, Chris Marsh <> wrote:
In your project cmake.
And I would not manually set these variables
Boost_DIR /usr/lib64/boost
I would let the find_pacakge call do that for you.
On 8 August 2017 at 13:56, Michael Bieri <> wrote:
Just in the cmake file of my project, or in the cmake file for building CGAL?
On Tue, Aug 8, 2017 at 9:48 PM, Chris Marsh <> wrote:
You put them before the find_package(Boost REQUIRED) call in your cmake file. You will not need to recompile boost.
For example:
set(Boost_NO_SYSTEM_PATHS TRUE)
set(BOOST_ROOT "/my/boost/boost_1_54_0")
message(STATUS "Found boost incl: ${Boost_INCLUDE_DIR}")
message(STATUS "Boost libs to link: ${Boost_LIBRARIES}")
message(STATUS "Found boost lib: ${Boost_LIBRARY_DIRS}")
should print your custom boost library path
On 8 August 2017 at 13:37, Michael Bieri <> wrote:
Hi Chris
Thanks for your answer. Where exactly should I put those lines, and do I need to recompile CGAL afterwards?
Best regards,
Michael
On Tue, Aug 8, 2017 at 9:29 PM, Chris Marsh <> wrote:
When compiling against a custom boost with cmake, you can use this in your cmake file to specify the boost directory
the FindBoost.cmake file will then pickup your custom directory
On 8 August 2017 at 13:14, Michael Bieri <> wrote:
Hello
I'm currently installing CGAL on different platforms. Normally, it works just fine. But I have one computer where Boost is not installed into the system, but just compiled in a directory. This Boost works properly in combination with other things I'm building, just not with CGAL.
I can compile CGAL using the following Boost-related settings, displayed with ccmake:
 Boost_DEBUG OFF
 Boost_INCLUDE_DIR /my/boost/boost_1_54_0
 Boost_LIBRARY_DIR /my/boost/boost_1_54_0/stage/lib
 Boost_SYSTEM_LIBRARY_DEBUG /my/boost/boost_1_54_0/stage/lib
 Boost_SYSTEM_LIBRARY_RELEASE /my/boost/boost_1_54_0/stage/lib
 Boost_THREAD_LIBRARY_DEBUG /my/boost/boost_1_54_0/stage/lib
 Boost_THREAD_LIBRARY_RELEASE /my/boost/boost_1_54_0/stage/lib
 CGAL_Boost_USE_STATIC_LIBS   OFF
Now, I'd like to compile one of my examples. I get the following error:
CMake Error at /usr/lib64/boost/Boost.cmake:536 (message):
  The imported target "boost_date_time-static" references the file
     "/usr/lib64/lib64/libboost_date_time.a"
  but this file does not exist.  Possible reasons include:
  * The file was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and contained
     "/usr/lib64/boost/Boost.cmake"
  but not all the files it references.
The error itself is not a surprise, because it's a very old Boost there.
Boost-related settings for cmake in my project folder are:
Boost_DEBUG OFF
Whe I change the variables to my own Boost in ccmake, it will also throw the above error and not save the changes.
So I really, really wonder: How do I set Boost properly to compile my own code? (I also tried with environment variables as given in the installation manual, Section 15.7.)
Best regards,
Michael
