cgal-discuss - Re: [cgal-discuss] Boost is not found when compiling my own code
  • To: <>
  • Subject: Re: [cgal-discuss] Boost is not found when compiling my own code
  • Date: Tue, 8 Aug 2017 14:42:16 -0600
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
I can only speak from experience in that for my custom built CGAL with a custom boost install, the instructions I linked works. Perhaps you are finding CGAL prior to setting the BOOST no system root?  That being said I've seen some strange differences between cmake on different machines, so I share your frustration. I guess as long as it works ....
On 8 August 2017 at 14:34, Michael Bieri <> wrote:
I built it a long time ago, and as far as I know, I also used the b2 engine. I see no CMake stuff in that boost directory.
So currently, it just works but I do not really understand what's going on.
On Tue, Aug 8, 2017 at 10:26 PM, Chris Marsh <> wrote:
Ah could be; I've never build boost with the cmake builder and only have used the b2 engine. I guess it behaves differently? Good to know.
On 8 August 2017 at 14:23, Michael Bieri <> wrote:
Ok, I think I finally got it when setting one more variable, Boost_NO_BOOST_CMAKE:
set(Boost_NO_SYSTEM_PATHS TRUE)
set(Boost_NO_BOOST_CMAKE TRUE)
set(BOOST_ROOT "/my/boost/boost_1_54_0")
find_package(Boost REQUIRED)
Best regards,
Michael
On Tue, Aug 8, 2017 at 10:10 PM, Michael Bieri <> wrote:
Ok, I tried to do this, but I get the following result when running it with --trace:
/my/project/CMakeLists.txt(25):  set(Boost_NO_SYSTEM_PATHS TRUE )
/my/project/CMakeLists.txt(26):  set(BOOST_ROOT /my/boost )
/my/project/CMakeLists.txt(27):  find_package(Boost REQUIRED )
/usr/share/cmake/Modules/FindBoost.cmake(163):  if(NOT Boost_NO_BOOST_CMAKE )
/usr/share/cmake/Modules/FindBoost.cmake(166):  if($ENV{Boost_DIR} STREQUAL  )
/usr/share/cmake/Modules/FindBoost.cmake(167):  if(NOT $ENV{BOOST_ROOT} STREQUAL  )
/usr/share/cmake/Modules/FindBoost.cmake(168):  set(ENV{Boost_DIR} $ENV{BOOST_ROOT} )
/usr/share/cmake/Modules/FindBoost.cmake(177):  find_package(Boost QUIET NO_MODULE )
/usr/lib64/boost/BoostConfigVersion.cmake(12):  if(${PACKAGE_FIND_VERSION_MAJOR}.${PACKAGE_FIND_VERSION_MINOR}.${PACKAGE_FIND_VERSION_PATCH} STREQUAL 1.41.0 )
/usr/lib64/boost/BoostConfig.cmake(20):  set(Boost_VERSION 1.41.0 )
/usr/lib64/boost/BoostConfig.cmake(21):  set(Boost_INCLUDE_DIRS /usr/include )
/usr/lib64/boost/BoostConfig.cmake(22):  set(Boost_INCLUDE_DIR /usr/include CACHE FILEPATH Boost include directory )
/usr/lib64/boost/BoostConfig.cmake(24):  set(Boost_LIBRARY_DIRS /usr/lib64 )
This will then again lead to the same error as before.
It seems that cmake absolutely wants to go into /usr/share/cmake/Modules/FindBoost.cmake and then /usr/lib64/boost/BoostConfig.cmake, no matter wheter I set Boost_NO_SYSTEM_PATHS TRUE.
Best regards,
Michael
On Tue, Aug 8, 2017 at 10:00 PM, Chris Marsh <> wrote:
In your project cmake.
And I would not manually set these variables
Boost_DIR /usr/lib64/boost
I would let the find_pacakge call do that for you.
On 8 August 2017 at 13:56, Michael Bieri <> wrote:
Just in the cmake file of my project, or in the cmake file for building CGAL?
On Tue, Aug 8, 2017 at 9:48 PM, Chris Marsh <> wrote:
You put them before the find_package(Boost REQUIRED) call in your cmake file. You will not need to recompile boost.
For example:
message(STATUS "Found boost incl: ${Boost_INCLUDE_DIR}")
message(STATUS "Boost libs to link: ${Boost_LIBRARIES}")
message(STATUS "Found boost lib: ${Boost_LIBRARY_DIRS}")
should print your custom boost library path
On 8 August 2017 at 13:37, Michael Bieri <> wrote:
Hi Chris
Thanks for your answer. Where exactly should I put those lines, and do I need to recompile CGAL afterwards?
Best regards,
Michael
On Tue, Aug 8, 2017 at 9:29 PM, Chris Marsh <> wrote:
When compiling against a custom boost with cmake, you can use this in your cmake file to specify the boost directory
the FindBoost.cmake file will then pickup your custom directory
On 8 August 2017 at 13:14, Michael Bieri <> wrote:
Hello
I'm currently installing CGAL on different platforms. Normally, it works just fine. But I have one computer where Boost is not installed into the system, but just compiled in a directory. This Boost works properly in combination with other things I'm building, just not with CGAL.
I can compile CGAL using the following Boost-related settings, displayed with ccmake:
 Boost_DEBUG OFF
 Boost_INCLUDE_DIR /my/boost/boost_1_54_0
 Boost_LIBRARY_DIR /my/boost/boost_1_54_0/stage/lib
 Boost_SYSTEM_LIBRARY_DEBUG /my/boost/boost_1_54_0/stage/lib
 Boost_SYSTEM_LIBRARY_RELEASE /my/boost/boost_1_54_0/stage/lib
 Boost_THREAD_LIBRARY_DEBUG /my/boost/boost_1_54_0/stage/lib
 Boost_THREAD_LIBRARY_RELEASE /my/boost/boost_1_54_0/stage/lib
 CGAL_Boost_USE_STATIC_LIBS   OFF
Now, I'd like to compile one of my examples. I get the following error:
CMake Error at /usr/lib64/boost/Boost.cmake:536 (message):
  The imported target "boost_date_time-static" references the file
     "/usr/lib64/lib64/libboost_date_time.a"
  but this file does not exist.  Possible reasons include:
  * The file was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and contained
     "/usr/lib64/boost/Boost.cmake"
  but not all the files it references.
The error itself is not a surprise, because it's a very old Boost there.
Boost-related settings for cmake in my project folder are:
Boost_DEBUG OFF
Whe I change the variables to my own Boost in ccmake, it will also throw the above error and not save the changes.
So I really, really wonder: How do I set Boost properly to compile my own code? (I also tried with environment variables as given in the installation manual, Section 15.7.)
Best regards,
Michael
