cgal-discuss - Re: [cgal-discuss] Mesh deformation produces strange results
  • To:
  • Subject: Re: [cgal-discuss] Mesh deformation produces strange results
  • Date: Thu, 17 Aug 2017 09:37:18 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:gBhOFBbwwVygm2SuBlvMZPD/LSx+4OfEezUN459isYplN5qZpsS+bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUD0OgNxY+j0AYXPlN+f1uao+pSVbR8bqiC6ZOY4Fxi8pB7Nt8QQya9lMKc21lOJjXZPfulK33JGLFmPmAztp434qIVn9D5RvO5n8spoXqDzfqB+RrtdWmd1e1sp7dHm4EGQBTCE4WERBz0b
On 08/15/2017 04:02 PM, SirM2X wrote:
Oops! It seems that the code did not make it to the email version (thank you
Andreas for pointing it out!)
I have posted a snippet here:
https://gist.github.com/Maghoumi/b13f061aecd7db7057d596388bbc4014
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-deformation-produces-strange-results-tp4662924p4662925.html
Without having the transformation you apply to each vertex, it is hard to tell whether it is a bug or if the transformation is the natural result. What is see might not be surprizing depending on where the
control vertex are put.
Sebastien.
