- To:
- Subject: Re: [cgal-discuss] The problem about installing CGAL
- Date: Mon, 23 Oct 2017 10:46:42 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:d1S0sRNxrqsPSiUGWmUl6mtUPXoX/o7sNwtQ0KIMzox0K/T/rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZFRz7cAZ0Pe/oAZX6jsKt1un09YeATR9PgW/3Wr54JQ6qrAjX/u0Rm4plNu5x5RbOp3ZUYfV4zGh0IkiC3ly0sty0+4Ri9DgWvvYJ+MtJUKG8dKM9G+8LRA86Onw4sZW4/SLIShGCsyMR
Make sure you are using the same version of the compiler (32 vs 64) for the boost libraries and for the compilation of the CGAL program.
Sebastien.
On 10/21/2017 05:10 PM, 王月欢 wrote:
Yes, I have followed the guide to install CGAl and set the Boost_INCLUDEDIR and Boost_LIBRARDIR environment variables.
and the Boost_LIBRARYDIR contains the following:
Does the Boost's version or the directory(I did not place Boost in the C drive) cause the problem?
在 2017-10-21 04:29:38,"Sebastien Loriot (GeometryFactory)"
写道:
Did you follow the tutorial here:
https://www.cgal.org/download/windows.html#Boost
If yes, then check that BOOST_LIBRARYDIR contains the boost_thread and
boost_system libraries.
Sebastien.
On 10/19/2017 03:35 PM, 王月欢 wrote:
I got the problem about installing CGAL
The platform: Windows 10, cmake 3.6.2, vs 2015
I have tried the boost 1.65 64 bit and 1.55 bit,
but I always got a problem:
I have set the BOOST_ROOT, BOOST_LIBRARYDIR and BOOST_INCLUDEDIR.
- [cgal-discuss] The problem about installing CGAL, 王月欢, 10/19/2017
- <Possible follow-up(s)>
- Re: [cgal-discuss] The problem about installing CGAL, Sebastien Loriot (GeometryFactory), 10/23/2017
- Re:[cgal-discuss] The problem about installing CGAL, 王月欢, 10/23/2017
- Re: [cgal-discuss] The problem about installing CGAL, Laurent Rineau (CGAL/GeometryFactory), 10/23/2017
- Re:[cgal-discuss] The problem about installing CGAL, 王月欢, 10/25/2017
