- To:
- Subject: Re:[cgal-discuss] The problem about installing CGAL
- Date: Mon, 23 Oct 2017 18:10:59 +0800 (GMT+08:00)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:rRnC4xBZtfcLi7zVFUUrUyQJP3N1i/DPJgcQr6AfoPdwSP77ocbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760DgJBx+qNRZpPv+nXcnJnsGv3qaz/YfSakNGnn2mcLZqJVK3qwvW8cIZiI8nJqcqwQbSuSh0fLFdympsYF6ShB3h/dyY/Zh58i0Wtehy2dRHVPACh1xwGaNRCjs3Lm01+cTtnQXBUE2C6mZaWWNAwUkAOBTM8ByvBsS5iSD9rOcogCQ=
Thank you very much for the answer. The problem about boost has been solved.
I want to ask another question, have you seen the following problem:
在 2017-10-23 16:46:42,"Sebastien Loriot (GeometryFactory)" <> 写道: >Make sure you are using the same version of the compiler (32 vs 64) for >the boost libraries and for the compilation of the CGAL program. > >Sebastien. > >On 10/21/2017 05:10 PM, 王月欢 wrote: >> Yes, I have followed the guide to install CGAl and set the >> Boost_INCLUDEDIR and Boost_LIBRARDIR environment variables. >> >> and the Boost_LIBRARYDIR contains the following: >> >> >> >> Does the Boost's version or the directory(I did not place Boost in the C >> drive) cause the problem? >> >> >> >> 在 2017-10-21 04:29:38,"Sebastien Loriot (GeometryFactory)" <> 写道: >>>Did you follow the tutorial here: >>>https://www.cgal.org/download/windows.html#Boost >>> >>>If yes, then check that BOOST_LIBRARYDIR contains the boost_thread and >>>boost_system libraries. >>> >>>Sebastien. >>> >>>On 10/19/2017 03:35 PM, 王月欢 wrote: >>>> I got the problem about installing CGAL >>>> >>>> The platform: Windows 10, cmake 3.6.2, vs 2015 >>>> >>>> I have tried the boost 1.65 64 bit and 1.55 bit, >>>> but I always got a problem: >>>> >>>> I have set the BOOST_ROOT, BOOST_LIBRARYDIR and BOOST_INCLUDEDIR. >>>> >> >> > >-- >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://sympa.inria.fr/sympa/info/cgal-discuss > >
- [cgal-discuss] The problem about installing CGAL, 王月欢, 10/19/2017
- <Possible follow-up(s)>
- Re: [cgal-discuss] The problem about installing CGAL, Sebastien Loriot (GeometryFactory), 10/23/2017
- Re:[cgal-discuss] The problem about installing CGAL, 王月欢, 10/23/2017
- Re: [cgal-discuss] The problem about installing CGAL, Laurent Rineau (CGAL/GeometryFactory), 10/23/2017
- Re:[cgal-discuss] The problem about installing CGAL, 王月欢, 10/25/2017
