- To:
- Subject: Re: [cgal-discuss] The problem about installing CGAL
- Date: Mon, 23 Oct 2017 14:42:23 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:TMz/UhFdW2BAzu8leulmnp1GYnF86YWxBRYc798ds5kLTJ76rsywAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVTx7wPA4wKuXuEZPJlOy20fqz8tvdeVZmnj24NPlWJQisoAPN/vMXh4ZrN+5x4TTghjxnduNTyH9yNHyalAr7/NbxttY39y1Nof8n64haUKP3drkQRrNRCHIhKW9jt56jjgXKUQbavihUaW4RiBcdWwU=
That issue is seen when you try to configure an old version of CGAL with a
recent version of CMake. That is not possible, because of a change in CMake.
Laurent Rineau, PhD
- [cgal-discuss] The problem about installing CGAL, 王月欢, 10/19/2017
- <Possible follow-up(s)>
- Re: [cgal-discuss] The problem about installing CGAL, Sebastien Loriot (GeometryFactory), 10/23/2017
- Re:[cgal-discuss] The problem about installing CGAL, 王月欢, 10/23/2017
- Re: [cgal-discuss] The problem about installing CGAL, Laurent Rineau (CGAL/GeometryFactory), 10/23/2017
- Re:[cgal-discuss] The problem about installing CGAL, 王月欢, 10/25/2017
