- To:
- Subject: Re: [cgal-discuss] delaunay
- Date: Sun, 5 Nov 2017 13:22:12 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:qJpUMBO0maG2aM18ujkl6mtUPXoX/o7sNwtQ0KIMzox0KP36rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWP6yUPEED/KRZtPbayXZXDity+keG04ZzaJQtSwyGsZKt7axSwowKWvcYfhc5uK7061wDS8UdPLu9ZzGctKVOIlAvn/e+x+oRi+mJeoaEP7clFBKz8cr9wRLhZRGAvNW0uosTvtEObFFOn6X4VU2FQmR1NVVuWpCrmV4v853Op/tF23zOXaJX7
bonjout,
merci bien pour votre réponse,
mais moi je travail sur des polygons 2D (intersection bewtween 2 Polygons 2D), c'est pas de la triangulation si je me trompe pas bien sur ;
et bonne journée .
2017-11-05 12:38 GMT+01:00 MaelRL <>:
Hello,
You can find the documentation of the 3D triangulation classes here
<https://doc.cgal.org/latest/Triangulation_3/index.html> . Most iterators
and circulators are in the Triangulation_3
<https://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html>
class, which Delaunay_triangulation_3
<https://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Delaunay__triangulation__3.html>
inherits. For example, traversal of the finite incident cells can be done
using finite_incident_cells
<https://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Triangulation__3.html#a44ecc22cedfbaa0bdaad3be6a435fcce>
. Searching in the code of the CGAL library for calls to this function will
give you real use examples.
You can also find some useful examples of triangulations uses there
<https://doc.cgal.org/latest/Triangulation_3/examples.html> .
- [cgal-discuss] delaunay, sikai, 11/04/2017
- Re: [cgal-discuss] delaunay, MaelRL, 11/05/2017
- Re: [cgal-discuss] delaunay, anes ali, 11/05/2017
