cgal-discuss - Re: [cgal-discuss] Point_2 inside Polygon_2
  • To:
  • Subject: Re: [cgal-discuss] Point_2 inside Polygon_2
  • Date: Thu, 11 Jan 2018 15:15:47 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:17+VhBz79TzOdGnXCy+O+j09IxM/srCxBDY+r6Qd1OgRIJqq85mqBkHD//Il1AaPAd2Craocw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94HObwlSmDaxfa55IQmrownWqsQYm5ZpJLwryhvOrHtIeuBWyn1tKFmOgRvy5dq+8YB6/ShItP0v68BPUaPhf6QlVrNYFygpM3o05MLwqxbOSxaE62YGXWUXlhpIBBXF7A3/U5zsvCb2qvZx1S+HNsDwULs6Wymt771zRRDqhicJNzA3/mLKhMJukK1WuwiuqwBlzoPOfI2ZKPhzc6XAdt0aX2pBWcNRWjRfD4O8dYsPDvEBPfpfr4nlp1sBswa1CxWtBOzx1zBIh3n23aIk3OQ7DArL2xAvH9IUsHTVt9X5KakfXO+xwaTK1jjDYPZW1i386IjMaBwuvfaMXbdpfMfX1EIhFBvFg02OpYD5Oz6ZzOcAvmiB4+Z+SO6ihXQrpg5yrzWp28wikJPGhpgPxVDB7Sh5wJg6Jdm/SENjZN6rCppQtyWDO4toQcMuX3hkuCg1x7AFo5K7cy8KyJMoxx7bdfOLaZSH4hXmVOqJIDd4gmxqeK6nihqs7UStzvfwW8q03VpQsCZJj9fBumoC2hHQ8sSHT+Fy/kal2TaBzQDT7eRELFgomqrbMZ4hw6UwmocdvEnMGiL7ml77jKCTdko+++io7/7rbanhpp+ZL4N0kB3xMrwymsyjBuQ1KhQBX2eB9uS4zbHs4Ez5QK5Wgf0rianZq4vXJd8bp668Gw9ayJwv6xe5Dze80dQXh2MLLFxfeEHPs4+8MF7HJLX0DOy0nk+3uDZt3fHPeLP7UbvXKX2Wu7f7fK1h7FZcxUIJzN1T5pRbB6tJdPnzQE7q7YeEX0ARPAm9wuKhA9J4gNBNEVmTC7OUZfuB+WSD4fgidrHVNd0l/Q3lIv1g3MbAyHowmFsTZ66shMJFZ3WxH/AgKEKcMyO13oUxVFwStw97d9TEzUWYWGcKNXm3VqM4oDo8DdD+VNqRdsWWmLWEmRyDMNhWa2RBUA3eFH7pc8CaWK9JZn7CZMBmlTMAWP6qTIpzjRw=
Try to compare the coordinates of the square with the point
Le 11 janv. 2018 14:58, "xoru" <> a écrit :
How check the point q in Point_2 type
is inside Polygon? or outside?
Polygon_2 P;
Point_2 q  = Point_2(1, 0.6);
 P.push_back (Point_2 (0, 0));
 P.push_back (Point_2 (1, 0));
 P.push_back (Point_2 (1, 1));
 P.push_back (Point_2 (0, 1));
