cgal-discuss - Re: [cgal-discuss] Point_2 inside Polygon_2
  • To:
  • Subject: Re: [cgal-discuss] Point_2 inside Polygon_2
  • Date: Thu, 11 Jan 2018 15:25:24 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
In this case if a horizontal line cuts the polygon an  odd number of times, it is inside. If even it is outside
Le 11 janv. 2018 15:19, "xoru" <> a écrit :
Polygon is more complicatet than this example ;-)
W dniu 2018-01-11 15:15:47 użytkownik Christophe Riedinger <> napisał:
Try to compare the coordinates of the square with the point
Le 11 janv. 2018 14:58, "xoru" <> a écrit :
How check the point q in Point_2 type
is inside Polygon? or outside?
Polygon_2 P;
Point_2 q  = Point_2(1, 0.6);
 P.push_back (Point_2 (0, 0));
 P.push_back (Point_2 (1, 0));
 P.push_back (Point_2 (1, 1));
 P.push_back (Point_2 (0, 1));
