- To:
- Subject: Re: [cgal-discuss] Point_2 inside Polygon_2
- Date: Thu, 11 Jan 2018 15:27:47 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:8IO2+Rf68dFjSf8aQwLvR/shlGMj4u6mDksu8pMizoh2WeGdxcS+ZR7h7PlgxGXEQZ/co6odzbaO6ua4ASQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTahfL9+Ngm6oRnMvcQKnIVuLbo8xAHUqXVSYeRWwm1oJVOXnxni48q74YBu/SdNtf8/7sBMSar1cbg2QrxeFzQmLns65Nb3uhnZTAuA/WUTX2MLmRdVGQfF7RX6XpDssivms+d2xSeXMdHqQb0yRD+v6bpgRh31hycdLzM37X/ZisJwgqxYrhyuqRNwzIzIb4+aL/d+YqDQcMkGSWZdUMtcVSpMCZ68YYsVCOoBOP5VopX7p1QTtxuxGxOjBPjywTFInHD5xrc60+U8GgzBxgMgGc8BsG7Ko9rvL6ceS+61w7PTwjXZbvNbwjj955bPchAkv/6MQahwcMrfyUY1CwzFklKQqZblPj+PyusNtG2b4vNmWOmyhWAnrARxrSKuxscqkoTGmo0VxUrA9Sljx4Y1P9K4RUhmatCnCJtdry6XOopsTs8/X21luDw2x70YtZKhYSQHyYorywbCZ/GDfYWE+A/vWPqeLDtiin9pZaiziwuu/US9zOD3S9O630xQriVfl9nBrnAN2ALX6siAUvZx4F2t2TOI1w3S6exIO0U0mrDaK54l27IwkYcTsVjZEi/xhkX2jLWadkM69ei08+jnY7PmqYGAN4JshQzzM74iltGjDek4KAQDX3aX9f6h2LDi40H1WLBKgec3kqndvpDaP8MbpquhDgBP1IYs9gy/ACm839QDh3UHIkhKdwmdj4joIFzOL+73DfC6g1uyjDdr3fDHPrP7DZrRMnjDl63hfLZn50FAzwozyMhT54hIBbEZPPLzRkjxucTEAR82KQO0x//rB8h81oMFRW2PH7SZMLjJvF+T5uMvJvGMa5UPtDb8Lfgl/f/ugmUjlV8TZ6n6lacQPXu3F/AjL0SCamf3mf8AF30Lt0wwVr/EklqHBBdVa2y/Vrl0yDgxEoPuWY7FSpqgiafH0i6xBJx+aW1BD12QC2bmfo6YXO0dLimVJ5kywXQ/SbG9Rtp5hlmVvwjgxu8/d7uGymgjrZvmkeNNyajWnBA2+yZzCp7EgW6ASGR5gnkZSTY9wKdlsAp2zVLRifEk0cwdLsRa4rZyail/LYTVlbUoBN31Xw/dZMaHQV26Rc+3Rzo2S4BpmoJcUwNGA9ynyyv78W+qDrsSzeHZXtox9fyMmX34JsI4zGvakq4/jx8gT9cdbWA=
https://doc.cgal.org/latest/Polygon/index.html#Algorithms
On 1/11/2018 3:19 PM, xoru wrote:
Polygon is more complicatet than this example ;-)
W dniu 2018-01-11 15:15:47 użytkownik Christophe Riedinger <> napisał:
Try to compare the coordinates of the square with the point
Le 11 janv. 2018 14:58, "xoru"
<mailto:>>
a écrit :
How check the point q in Point_2 type
is inside Polygon? or outside?
Polygon_2 P;
Point_2 q = Point_2(1, 0.6);
P.push_back (Point_2 (0, 0));
P.push_back (Point_2 (1, 0));
P.push_back (Point_2 (1, 1));
P.push_back (Point_2 (0, 1));
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Point_2 inside Polygon_2, xoru, 01/11/2018
- Re: [cgal-discuss] Point_2 inside Polygon_2, Christophe Riedinger, 01/11/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] Point_2 inside Polygon_2, xoru, 01/11/2018
- Re: [cgal-discuss] Point_2 inside Polygon_2, Andreas Fabri, 01/11/2018
