cgal-discuss - Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?
  • To:
  • Subject: Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?
  • Date: Thu, 18 Jan 2018 08:32:57 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello,
You've forgotten to also pick the Vertex typedef from the "with_info"
example:
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
and replace
CGAL::Triangulation_vertex_base_3<K>
by this typedef in
typedef CGAL::Triangulation_data_structure_3<
CGAL::Triangulation_vertex_base_3<K>,
CGAL::Triangulation_cell_base_3<K>,
CGAL::Parallel_tag> Tds;
