- To:
- Subject: Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?
- Date: Thu, 18 Jan 2018 22:42:38 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:IlkUvxVjKsSUauBt9qrvL3pCHXzV8LGtZVwlr6E/grcLSJyIuqrYbBCAt8tkgFKBZ4jH8fUM07OQ7/i5HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba9vIBmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W7VhMx+jKxVrhG8qRJh34HZe5uaOOZkc67HYd8WWWhMU8BMXCJBGIO8aI4PAvIcMOZZtIn8qUEBrRm/BQmwGeji1z5IhmT43KIgyOQqDAbL0xchH9IVvnXbttf1NKYOUeyv0KbI1i/PY+5K1Trm54jIdwouofCIXb5qbcXRzkwvGhrDg16Np4LlODaV2f4Ms2id9+dgU/ighHU8pAF1vDej3Nsjio7Mho4Ny1DE8z95wIcvKtGiRk57e9ipG4ZTuSGCL4Z6XN8uTmVytCs5yrAKo4C3cDUIxZg92hLSb/KKfo6V6Rz5TumROy13hHd9dbK/mRmy9U+gx/X5Vsau0VZKqjNJksTWuXwRzhDT5NWLR/9z80u71jaP0AfT6u5AIU8qj6bUN5khwrsompoSt0TMADP2lV3ogKOKckgo4Oul5uT9brn4u5ORNZV4hhz6P6kggsC/BP43MgkKX2iV4+S807jj8FXiT7VLlf03nLPWsJLbJcQHvKK2HxRV3pw+5xqjFDqm39EYkmMGLFJBYh6Ik4/pO1TWLPDiEfi/m0iskCtsx/3eIrLhDY/CLnzanLj8fLZ98FJTyBcozdBE/J9UEbEAIPfrWkDrrtDYDxk5Mxa1w+n9Etl92JkeCiqyBLSEOvbSrUOQ/bBoZPKdYZcc/jf7MfksofD0ymQonEcUOqiv05xQY3+xGrFqIl6SfGH30esGRGwFtw57QO3xg0CZShZSYWyzVuQy/GIVEoWjWK3CXZ+kgr2dlA26BYJffSgSAFGXDn7qdpnCUOxKMXq6LcpokzhCXr+kHdxynSqyvRP3nuI0ZtHf/TcV4Mq6hYpFotbLnBR3zgRaSsGU0mWDVWZxxzpaSDo/3aQ5qkt4mA7ajfpIxsdAHNkW3MtnFx8gPMeFneN/AtH2HAnGe4XREQv0cpCdGTg0C+kJ7ZoObkJ6QYvwixnC22+3CudQmeXaX9o79aXT23W3LMF4mS7L
horrible........
On Thu, Jan 18, 2018 at 9:02 PM, MaelRL <> wrote:
Hello,
You've forgotten to also pick the Vertex typedef from the "with_info"
example:
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K> Vb;
and replace
CGAL::Triangulation_vertex_base_3<K>
by this typedef in
typedef CGAL::Triangulation_data_structure_3<
CGAL::Triangulation_vertex_base_3<K>,
CGAL::Triangulation_cell_base_3<K>,
CGAL::Parallel_tag> Tds;
thanks and regards
mobile:9163016823
- [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Thierry Fredrich, 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Sebastien Loriot (GeometryFactory), 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Thierry Fredrich, 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, MaelRL, 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Biswajit Biswas, 01/18/2018
