cgal-discuss - Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure
  • To:
  • Subject: Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure
  • Date: Mon, 26 Feb 2018 12:24:47 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
I see the bad triangles, but I don't understand where the constraints are, on your figure. Can you please highlight them?
Le 24/02/2018 à 01:00, chrism a écrit :
Ok this is odd. I made some changes this morning (nothing related to my
constraint code) and recompiled, problem is gone. I can run the domain with
lloyd optimization without issue. However, the resulting "optimized" mesh is
of poor quality. Many small, thin (non-Delauany) triangles are present along
the constraint (circled in red). I've attached an image to show what I mean
where I ran max of 100 lloyd iterations. Is this expected behaviour? All the
other meshes I run lloyd iterations on produce high quality meshes.
<http://cgal-discuss.949826.n4.nabble.com/file/t375307/File_001.png>
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
