- To:
- Subject: Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure
- Date: Tue, 27 Feb 2018 12:05:02 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:I+pkaxBKvkVcY/mJf2DHUyQJP3N1i/DPJgcQr6AfoPdwSPX5osbcNUDSrc9gkEXOFd2Cra4c0KyO6+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglUijexe69+IAmrpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+VrxYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs5Xymp4aV2Rx/ykCoJKiA38G/XhMJzgqxUrh2uqB5jzIPPeo6ZKOBzc7nBcd4UR2dMWNtaWSxbAoO7aosCF+4PMvxer4bjulAAsxy+BRS2BOPpzT9Ih2T21rA93uQjCw7G2hIvE8gSsHTTsdX1LqESUee0zKnT1jjDYO1Z2TD46IfWbhAhu/GNXbxqfsXN1UkvEBnFj1WKpYP5ODOV0/0Avm6G5ORuUuKvjnQoqwB3ojW3wMcjkJLGiZkRyl/a7yl23IE1JdigRE50Zd6kF4BfuDueN4dvWcMtX2BotDw9yr0ctp63ZDQFyJs9yB7bcfCHdJKI4h37WOaePzh4g3dld6yjhxao8UmgxPfzWdWo0FZNtCpEksPAuWwK1xzW7MWMV/hz/l+51DqS1Q3e6ftILE46mKbBJJMsw6Q8mocPvUjbAyP7nEv7gLWLekk49eWk8erqbqj8qpOBK4N4lwfzObk0lMOlG+Q3KA0OUnCb+eui0L3j+lX0TbpQgv0zlanUvorWJcEBqa64Bw9Zy4Ej6wujDzu819QYg3kHIEhDeB2Zk4jlI1DOIPbmAvejm1mgjTVmyvPcMrDvDJjBNHfOnbb7cbpg90JQ0A8zwspe55JQBLEBOvXzWkrpudzaFBA5NRK7z/z7CNV6y4MeQ2SPAqiYMKPJqlKI6fwgI+6JZIALpDb9Mfgk5/D0gnAlhV8derOp3JsNZH+kGfRmJl2VYWDwjdcZDWcKog0+QfT2h12NSzFTY2++UL895jEgFI2mEJzDRpu2jbya3Ca7G4VWaXpcBlCNF3fobYSEVO0WZCKcOM8y2gADALOuQotk2RC1vxLh0JJmKPDV82sWr8HNzt9wss/akxx6yTtpFcKa0nrFG2N9mG5OWzgrxqZ4oFdVxVqE1KVkme1WHNdP4OlYFAw9MMiPnKRBF9nuV1eZLZ+yQ1G8T4D+WGBjfpcK29YLJn1FNZCnhxHH0TCtBuVMxbOGA5k57rjN0XH6O8Fn2jDN06xz1wB6EPsKDnWvg+tEzyaWH5TAyRzLmKutcKkAxj/D/WyfynCf+kpfVVwoCPiXbTUkfkLT6O/ByAbCQrupU+h1bk1EzpXEL6JLbpjukEkAQ+njftLTfzDplg==
Hi Chris, I understand what you mean. You can have a look at this paper for more details on our
algorithm : The triangles that are called "blind" (meaning that their
circumcenter is on the other side of a constrained edge) can
hardly have a good shape without refining the associated
constrained edge. If you want better shaped triangles close to constrained edges, they should be refined using the Delaunay_mesh_size_criteria_2 [1]. Also note that the Lloyd smoothing algorithm is enriched with a sizing field that locally preserves the mesh density through iterations. So, the vertices that are close to constraints should remain close to constraints. It avoids creating needle-shaped triangles next to constraints. Best regards, Jane.
[1]
https://doc.cgal.org/latest/Mesh_2/classCGAL_1_1Delaunay__mesh__size__criteria__2.html Le 26/02/2018 à 18:06, chrism a écrit :
Ah, sorry. Please find the comparison as presented above with the constraint shown in red. <http://cgal-discuss.949826.n4.nabble.com/file/t375307/lloyd.png> As I cannot attach a large image, it may be difficult to see exactly? If so, I have paraview compatible VTU files as well as the triangulation and constraint in ESRI shape files (shp) to load into a GIS, such as qGIS. -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ -- Jane Tournois, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ |
- [cgal-discuss] lloyd optimization mesh 2 assertion failure, Chris Marsh, 02/23/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Jane Tournois, 02/23/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, chrism, 02/24/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Jane Tournois, 02/26/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, chrism, 02/26/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Jane Tournois, 02/27/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Christophe Riedinger, 02/27/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, chrism, 02/28/2018
