cgal-discuss - [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve)
  • To:
  • Subject: [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve)
  • Date: Fri, 11 May 2018 11:40:10 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
-------- Forwarded Message -------- Subject: Re: [cgal-discuss] CGAL::cpp11::next(vb,ve) Date: Fri, 11 May 2018 10:30:28 +0200 From: Andreas Fabri <> To: iampriyanshi <>
It applies 47 times  operator++  to the iterator.
andreas
On 5/11/2018 10:23 AM, iampriyanshi wrote:
What does the below statement do?
*CGAL::cpp11::next(vb, 47)
where
typedef boost::graph_traits<Polyhedron>::vertex_iterator
vertex_iterartor
vertex_iterator vb;
Code:
https://doc.cgal.org/latest/Surface_mesh_deformation/Surface_mesh_deformation_2k_ring_roi_translate_rotate_example_8cpp-example.html
