- To:
- Subject: Re: [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve)
- Date: Fri, 11 May 2018 15:30:07 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Also
what does "boost::tie(vb,ve) = vertices(mesh) " do?
where mesh is a Polyhedron
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3> Polyhedron;
On Fri, May 11, 2018 at 3:10 PM, Andreas Fabri <> wrote:
-------- Forwarded Message --------
Subject: Re: [cgal-discuss] CGAL::cpp11::next(vb,ve) Date: Fri, 11 May 2018 10:30:28 +0200 From: Andreas Fabri <> To: iampriyanshi <>
It applies 47 times operator++ to the iterator.
andreas
On 5/11/2018 10:23 AM, iampriyanshi wrote:
What does the below statement do? *CGAL::cpp11::next(vb, 47) where typedef boost::graph_traits<Polyhedron>::vertex_iterator vertex_iterartor vertex_iterator vb; Code: https://doc.cgal.org/latest/Surface_mesh_deformation/Surface_mesh_deformation_2k_ring_roi_translate_rotate_example_8cpp-example.html -- Sent from: http://cgal-discuss.949826.n4.nabble.com/
Kind regards,
PRIYANSHI
- [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve), Andreas Fabri, 05/11/2018
- Re: [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve), Priyanshi Kumari, 05/11/2018
- Re: [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve), Andreas Fabri, 05/11/2018
