cgal-discuss - Re: [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve)
  • To:
  • Subject: Re: [cgal-discuss] Fwd: Re: CGAL::cpp11::next(vb,ve)
  • Date: Fri, 11 May 2018 15:49:40 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Thanks
On Fri, May 11, 2018 at 3:38 PM, Andreas Fabri <> wrote:
As it is boost::tie looking up the documentation might help.
vertices() returns a std::pair
boost::tie  takes first and second out of the pair and ties it to the two variables.
It is in fact more general, that is it works for any tuple.
andreas
On 5/11/2018 12:00 PM, Priyanshi Kumari wrote:
Also
what does    "boost::tie(vb,ve) = vertices(mesh) " do?
where mesh is a Polyhedron
typedef CGAL::Simple_cartesian<double>                                   Kernel;
typedef CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>  Polyhedron;
On Fri, May 11, 2018 at 3:10 PM, Andreas Fabri <> wrote:
-------- Forwarded Message --------
Subject: Re: [cgal-discuss] CGAL::cpp11::next(vb,ve)
Date: Fri, 11 May 2018 10:30:28 +0200
To: iampriyanshi <>
It applies 47 times  operator++  to the iterator.
andreas
On 5/11/2018 10:23 AM, iampriyanshi wrote:
What does the below statement do?
*CGAL::cpp11::next(vb, 47)
where
typedef boost::graph_traits<Polyhedron>::vertex_iterator
vertex_iterartor
vertex_iterator vb;
Code:
https://doc.cgal.org/latest/Surface_mesh_deformation/Surface_mesh_deformation_2k_ring_roi_translate_rotate_example_8cpp-example.html
Kind regards,
PRIYANSHI
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912    skype: andreas.fabri
Kind regards,
PRIYANSHI
