cgal-discuss - Re: [cgal-discuss] How to convert from stl to off and off to stl?
  • To:
  • Subject: Re: [cgal-discuss] How to convert from stl to off and off to stl?
  • Date: Wed, 6 Jun 2018 23:30:10 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Easiest way is to use Meshlab. It allows conversation between various formats. Open any stl mesh, and go to export as off.
Possibly polyhedron demo could also do that. Haven't tried. There are examples of mesh io in cgal as well. You could use that may be. Having said so I personally use both meshlab for this purpose.
On Wed, Jun 6, 2018, 9:07 PM sergio <> wrote:
My application only use STL files, How to convert from stl to off and off to
stl?
