- To:
- Subject: Re: [cgal-discuss] How to convert from stl to off and off to stl?
- Date: Wed, 6 Jun 2018 20:40:03 +0200
These formats in geogram: http://alice.loria.fr/software/geogram/doc/html/index.html The bundled 'vorpalite' command line utility can be used to convert between file formats: vorpalite profile="convert" input.stl output.off
-- B
On 06/06/2018 08:00 PM, Sukhraj Singh
wrote:
Easiest way is to use Meshlab. It allows
conversation between various formats. Open any stl mesh, and go
to export as off.
Possibly polyhedron demo could also do that.
Haven't tried. There are examples of mesh io in cgal as well.
You could use that may be. Having said so I personally use
both meshlab for this purpose.
On Wed, Jun 6, 2018, 9:07 PM sergio <>
wrote:
My
application only use STL files, How to convert from stl to off
and off tostl? -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss |
- [cgal-discuss] How to convert from stl to off and off to stl?, sergio, 06/06/2018
- Re: [cgal-discuss] How to convert from stl to off and off to stl?, Sukhraj Singh, 06/06/2018
- Re: [cgal-discuss] How to convert from stl to off and off to stl?, Shankar Kulumani, 06/06/2018
- Re: [cgal-discuss] How to convert from stl to off and off to stl?, Bruno Levy, 06/06/2018
- Re: [cgal-discuss] How to convert from stl format to off forma and vice versa?, sergio, 06/07/2018
