- To:
- Subject: Re: [cgal-discuss] CGAL : centroid and BigFLoat
- Date: Tue, 12 Jun 2018 13:02:37 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
BigFloat does not have a constructor from unsigned int so it makes the call in centroid ambiguous as you noted.
Should be fixed by https://github.com/CGAL/cgal/pull/3166
Sebastien.
On 06/08/2018 11:38 AM, Tom Dreyfus wrote:
Hello,
I have some trouble using the CORE::BigFloat number type with the centroid function of CGAL, and I did not see any body with the same problems.
Here is a minimal example that does not compile for me :
/#include <CGAL/CORE_BigFloat.h>//
//#include <CGAL/Cartesian.h>//
//#include <CGAL/centroid.h>//
//typedef CGAL::Cartesian<CORE::BigFloat> K;//
//int main(int argc, char *argv[]){//
// std::vector<K::Point_3> points;//
// K::Point_3 c = CGAL::centroid(points.begin(), points.end());//
// return 0;}/
I have the following error :
**/usr/include/CGAL/centroid.h:425:23: error: call of overloaded ‘BigFloat(unsigned int&)’ is ambiguous**
** return ORIGIN + v / (FT)nb_pts;**
I can solve this by simply turning the unsigned nb_points into an int, but there is may be something I did not see, or the problem is solved in a more recent version of CGAL ?
My environment is :
_Compiler_ : GNU 6.3.1, /usr/lib64/ccache/c++
_OS_ : Fedora 25
_CGAL_ : 4.9.1 installed with dnf
Thanks !
Tom.
- [cgal-discuss] CGAL : centroid and BigFLoat, Tom Dreyfus, 06/08/2018
- Re: [cgal-discuss] CGAL : centroid and BigFLoat, Sebastien Loriot (GeometryFactory), 06/12/2018
