cgal-discuss - [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?
  • To:
  • Subject: [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?
  • Date: Thu, 14 Jun 2018 07:19:13 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Is there a way to write and read WKT strings?
Example:
POLYGON((0 0, 10 0, 10 11, 11 10, 0 10)) or MULTIPOLYGON....
and convert it to CGAL::Surface_mesh<K::Point_3> ?
I would like to repair self-intersection in multipolygons using
autorefine_and_remove_self_intersections() for example, is it posible?
