cgal-discuss - Re: [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?
  • To:
  • Subject: Re: [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?
  • Date: Thu, 14 Jun 2018 17:02:42 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
I am in both. I have self intersection in 3D and after 3D mesh is sliced I get polygons which has self-intersection too.
On Thu, Jun 14, 2018 at 4:57 PM, Sebastien Loriot (GeometryFactory) <> wrote:
Are you in 2D or 3D?
Sebastien.
On 06/14/2018 04:19 PM, sergio wrote:
Is there a way to write and read WKT strings?
Example:
POLYGON((0 0, 10 0, 10 11, 11 10, 0 10)) or MULTIPOLYGON....
and convert it to CGAL::Surface_mesh<K::Point_3> ?
I would  like to repair self-intersection in multipolygons  using
autorefine_and_remove_self_intersections() for example, is it posible?
