Re: [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?
- To:
- Subject: Re: [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?
- Date: Thu, 14 Jun 2018 16:57:53 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Are you in 2D or 3D?
Sebastien.
On 06/14/2018 04:19 PM, sergio wrote:
Is there a way to write and read WKT strings?
Example:
POLYGON((0 0, 10 0, 10 11, 11 10, 0 10)) or MULTIPOLYGON....
and convert it to CGAL::Surface_mesh<K::Point_3> ?
I would like to repair self-intersection in multipolygons using
autorefine_and_remove_self_intersections() for example, is it posible?
- [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?, sergio, 06/14/2018
- Re: [cgal-discuss] Is there a way to write and read WKT strings and con convert it to CGAL::Surface_mesh<K::Point_3> ?, Sebastien Loriot (GeometryFactory), 06/14/2018
