cgal-discuss - Re: [cgal-discuss] strange variable name
  • To:
  • Subject: Re: [cgal-discuss] strange variable name
  • Date: Mon, 9 Jul 2018 10:03:37 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Are you sure you don't have a global variable in defined somewhere?
Could you share the error message you have?
Thanks,
Sebastien.
On 07/09/2018 12:18 AM, j. scheurich wrote:
I use the headerfile only version of cgal 4.12 with visual c++ 2017 community.
I have to change lines 122ff of File_header_extended _OFF.h to:
// istream modifier that checks for OFF comments and removes them.
inline std::istream& skip_comment_OFF( std::istream& in2) {
    char c;
    while( (in2 >> c) && c == '#')
        in2 >> skip_until_EOL;
    in2.putback(c);
    return in2;
it looks like "in" is now a reserved C++ word 8-(
so long
MUFTI
