- To:
- Subject: Re: [cgal-discuss] linking error
- Date: Mon, 9 Jul 2018 10:04:27 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Could you describe the steps you did to use the header only version
and when did you get the error message?
Thanks,
Sebastien.
On 07/09/2018 01:42 AM, j. scheurich wrote:
I use the headerfile only version of cgal 4.12 with visual c++ 2017 community.
i got the following linking errror:
>LINK : fatal error LNK1104: Datei "libCGAL-vc140-mt-gd-4.12.lib" kann nicht geƶffnet werden.
...can't be opened
so long
MUFTI
- [cgal-discuss] linking error, j. scheurich, 07/09/2018
- Re: [cgal-discuss] linking error, Sebastien Loriot (GeometryFactory), 07/09/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/09/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/10/2018
- Re: [cgal-discuss] linking error, Sebastien Loriot (GeometryFactory), 07/10/2018
- Re: [cgal-discuss] linking error, Laurent Rineau (CGAL/GeometryFactory), 07/10/2018
- Re: [cgal-discuss] linking error, j. scheurich, 07/11/2018
- Re: [cgal-discuss] linking error, Laurent Rineau (CGAL/GeometryFactory), 07/11/2018
