cgal-discuss - RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
  • To: "" <>
  • Subject: RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
  • Date: Mon, 9 Jul 2018 08:02:26 +0000
  • Accept-language: fr-FR, en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=PermError ; spf=Pass
  • Ironport-phdr: 9a23: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
  • Spamdiagnosticmetadata: NSPM
  • Spamdiagnosticoutput: 1:99
Hello,
Here is the point cloud in PLY format:
https://drive.google.com/file/d/1cPcxFLQCccmd2X1OWzunc0WtRIiuM9f0/view?usp=sharing
Best,
Bien cordialement.
Kilian Demeulemeester
Directeur R&D
Snapkin | Outil de mesure et de mise en plan 2D/3D pour le bâtiment.
Tél : +33 (0)7 83 49 82 36 | Discutons !
-----Message d'origine-----
De :
De la part de Simon Giraudot
Envoyé : lundi 9 juillet 2018 09:27
À :
Objet : Re: [cgal-discuss] Point Set Shape Detection - connected component do
Hello,
Le 06/07/2018 à 15:33, Kilian Demeulemeester a écrit :
> The point cloud is available here:
> https://drive.google.com/open?id=1r4-9vLq35L6c4SwlGvqppzv6-wrP8nfV (108Mo).
I can't seem to open E57 files, could you convert your point cloud to another
format? (PLY, OFF, LAS, XYZ.)
Thank you,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
> We are using CGAL 4.10.2.
> I've seen that there has been changes relative to that package but...
> nothing related to this.
> I've checked the release note and didn't see anything related to that bug.
> I've also blamed the changes of the method connected_component in
> CGAL\Shape_detection_3\Shape_base.h - and did not find any changes lately.
> As for now, I think I will try to extend the class
> CGAL::Shape_detection_3::Plane<Traits> to create my own version - and
> overload the connected_component method to use our own version (using
> opencv).
> Bien cordialement.
> Directeur R&D
> De :
> Envoyé : vendredi 6 juillet 2018 15:04
> À :
> Hello,
> This is indeed unexpected. From what you explain in your email, I don't
> think you did anything wrong, so I suspect there is a bug in the package.
> What version of CGAL do you use? There has been some changes in the Shape
> Detection package lately (but if I remember correctly, nothing that
> addresses a bug like this one).
> Is there any way you could you share the point cloud so I can try to
> reproduce it and find where is the bug?
> Best,
> Simon Giraudot, PhD
> R&D Engineer
> Le 06/07/2018 à 10:16, KDemeul a écrit :
>> Hello,
>> I am trying to use the Point Set Shape Detection
>> <https://doc.cgal.org/latest/Point_set_shape_detection_3/index.html#Chapter_Point_Set_Shape_Detection>
>> package - in order to detect PLANEs only.
>> I've defined the value of the parameters as follow:
>> -probability=0.01
>> - minPoints=10000
>> - epsilon=0.01
>> - clusterEpsilon=0.05
>> - normalThreshold=0.9
>> However, it seems that the clusterEpsilon parameter is not correctly taken
>> into account.
>> Here is an example of a plane detected by the algorithm.
>> As one can see, the left part is disconnected from the right part - by a
>> gap
>> of approx 1.6m.
>> <http://cgal-discuss.949826.n4.nabble.com/file/t375977/Sans_titre.png>
>> Is there something I don't get?
>> Best regards,
>> Kilian Demeulemeester.
>> Sent from: http://cgal-discuss.949826.n4.nabble.com/
