- To:
- Subject: Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?
- Date: Tue, 14 Aug 2018 09:32:00 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello, As far as I know, there is no direct function. Maybe simpler than sorting the edges, you can loop over vertices
and walk the border (for example by treating the triangulation as
a graph and using CGAL::halfedges_around_target
to loop on the incident faces while they are classified as
exterior). Another maybe even simpler way would be to use the
adaptor Face_filtered_graph
on your triangulation to discard all the faces of the
triangulation that are marked as exterior in the alpha shape. You
can then just walk the border of your graph using BGL
functions and CGAL's BGL
helper functions. Best, On 12/08/18 14:44, brainslush wrote:
Is there a circulator which walks along the hull of a calculated 2D alpha shape? I know that I can extract the edges via iterating through alpha_shape_edges_begin() to alpha_shape_edges_end(). But it returns the edges in an unordered way. I probably could sort them but since I'm trying to avoid any unnecessary overhead I was wondering if something like this exists. Thanks -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ |
- [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, brainslush, 08/12/2018
- Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, Mael, 08/14/2018
- Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, brainslush, 08/21/2018
- Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, Renato Silveira, 08/27/2018
