- To:
- Subject: Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?
- Date: Mon, 27 Aug 2018 05:05:40 -0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:k4K2IBGzUcShE7il76SDwZ1GYnF86YWxBRYc798ds5kLTJ7zpM+wAkXT6L1XgUPTWs2DsrQY07WQ6/iocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbAhEmDiwbaluIBmqsA7cqtQYjYx+J6gr1xDHuGFIe+NYxWNpIVKcgRPx7dqu8ZBg7ipdpesv+9ZPXqvmcas4S6dYDCk9PGAu+MLrrxjDQhCR6XYaT24bjwBHAwnB7BH9Q5fxri73vfdz1SWGIcH7S60/VDK/5KlpVRDokj8KODE38G7VisJ+gqFVrg+/qRNj2IPbep2ZOeBkc6/BYd8XR2xMVdtRWSxbBYO8apMCAfYfMuZetYb9u1wOpgajCwmtAOPv1CFHhn7s3aIgzu8sFhrG3A0kH9IQrnvUrc/1O70IXeCv0qbIyy7Ob/xT2Tjn6YjIdgotru2LXbJ1aMfcz1QkGQ3CjlWVs4PlPjWV2/wLs2eB9OVvTuavhHA9pw5tpTivw98giojPhoIPy1DL7z91wIgvJdC+VUV1YsakHYNOuy2GM4Z6WMAvTmFytCok17ELtoS3cSgUxJkh2hXRceaIc5KS7RLmTOuRISl3hHZieL+ngha960mgyunlWsm1zFZGsjNJktfMu3wTzRDT5c+HSvxy/kelxzmDzRzc6uZBIUwslKrbLYAuwqIom5YNrUjOGjX6lUb2gaOMaEko5+el5/7nb7n4vpOcMpV7igD6MqQggMy/BuE4PxAVX2ia/eS8yqPs/UzjQLpQlPE2iLfWsJbBKMQUo662GQ5V0oI55xmjCDem1cwUnWMbI1JdZBKHk4/pNknSL/D3F/i/h02gnypqx/DdIrLhH47NLmPYnbf6fbd97lZcxxApwdBe4ZJUELABL+jpVk//rtyLRiI/KBG+lub7FM1mhMRZQnOKGqbfMaXIsFbO6PhoOPiJfIZSuTDzLL8u6PfqyHM4glQAZrL64ZxCY3+xGrFqIl6SfGH3qtYHC2YD+AQkH8Lwj1jXazNVbmq1F5k94i82CZivRdPYR4Szjb2b1WGhE5t+aWVPC1TKGnDtIdbXE8wQYT6fd5cy2gcPUqKsHtd4hEOe8TTiwr8iFdL6vygRtJbtzt9wvrSBmhQ79DgyBMOYgTjUEzNE21gQTjpz55hR5FRnww7ag6d9iv1cU9dU4qERC1poBdvn1+V/TuvKdEfBc9OOEgv0R9ynBXQwUop0zYJUJUl6HNqmg1bI2C/4W7I=
Can you share with me the code? I will face this problem soon!
Thank you!
I ended up writing my own instruction which is reasonably fast but thanks
anyway. If someone is interested I can share the code.
Renato Silveira
Ph.D. in Computer Science
NTU / UFRGS | Núcleo de Tecnologia Urbana
Porto Alegre - RS - Brazil
- [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, brainslush, 08/12/2018
- Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, Mael, 08/14/2018
- Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, brainslush, 08/21/2018
- Re: [cgal-discuss] Is there a circulator for the hull of a 2d alpha shape?, Renato Silveira, 08/27/2018
