- To:
- Subject: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?
- Date: Sat, 25 Aug 2018 17:29:35 +0430
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi, I want to use Dual class to construct a dual graph of my arrangement, but I get the compile error :
C2079: 'dual' uses undefined class 'CGAL::Dual<Arr_with_hist_2>'
and I think it's for Arrangement_with_history_2 that I use to define the arrangement in the code. Now I need to convert Arr_with_hist_2 to Arrangement_2 and I don't know how to do this?
my CGAL type definition :
typedef CGAL::Cartesian<CGAL::Exact_rational> Kernel;
typedef Kernel::Circle_2 Circle_2;
typedef Kernel::Segment_2 Segment_2;
typedef CGAL::Arr_circle_segment_traits_2<Kernel> Circle_Segment_traits_2;
typedef std::string Curve_Name;
typedef CGAL::Arr_consolidated_curve_data_traits_2
<Circle_Segment_traits_2, Curve_Name> Traits_2;
typedef Traits_2::Point_2 TPoint_2;
typedef Traits_2::Curve_2 Curve_2;
typedef Traits_2::CoordNT CoordNT;
typedef CGAL::Arr_face_extended_dcel<Traits_2 , unsigned int> Dcel ;
typedef CGAL::Arrangement_with_history_2<Traits_2, Dcel> Arr_with_hist_2; typedef CGAL::Dual<Arr_with_hist_2> Dual_arrangement; typedef CGAL::Arr_face_index_map<Arr_with_hist_2> Face_index_map;
- [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Morteza Manavi, 08/25/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Efi Fogel, 08/25/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Morteza Manavi, 08/26/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Efi Fogel, 08/26/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Sebastien Loriot (GeometryFactory), 08/28/2018
