cgal-discuss - Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?
  • To:
  • Subject: Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?
  • Date: Sun, 26 Aug 2018 15:48:47 +0430
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Exactly, compiler give error:
C2079: 'dual' uses undefined class 'CGAL::Dual<Arr_with_hist_2>'
C2440: 'initializing': cannot convert from 'Arr_with_hist_2' to 'int'
in line :
Dual_arrangement  dual(arr);
of my code.
(Notice that the error is not occur at runtime)
On Sun, Aug 26, 2018 at 2:47 PM Efi Fogel <> wrote:
What makes you think that the Dual class does not accept Arrangement_with_history_2?
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On Sun, 26 Aug 2018 at 12:15, Morteza Manavi <> wrote:
Thank you Efi,
But I don't want to delete CGAL::Dual because I need to construct a dual graph representation of the arrangement, and on the other hand I need to have curve handler that it's possible with use of Arrangement_with_history_2 class.
Apparently the Dual class does not accept Arrangement_with_history_2 as input and according to your answer I can't directly convert Arrangement_with_history_2 to Arrangement_2. I think, I must write my own dual graph class that accept Arrangement_with_history_2 as input.
Morteza.
On Sun, Aug 26, 2018 at 1:50 AM Efi Fogel <> wrote:
Hi Morteza,
If you really need to convert Arrangement_with_history_2 to Arrangement_2, then you would need to reconstruct Arrangement_2, but conceptually, everything you can do with Arrangement_2 you can also do with Arrangement_with_history_2.
Is it possible that you simply forgot to include the header that contains the definition of CGAL::Dual, namely, <CGAL/graph_traits_Dual_Arrangement_2.h> ?
Anyway, if you still have a problem, please paste a complete minimal program.
Efi
   ____  _        ____             _
                         _/
On Sat, 25 Aug 2018 at 16:00, Morteza Manavi <> wrote:
Hi, I want to use Dual class to construct a dual graph of my arrangement, but I get the compile error :
and I think it's for Arrangement_with_history_2 that I use to define the arrangement in the code. Now I need to convert Arr_with_hist_2 to Arrangement_2 and I don't know how to do this?
my CGAL type definition :
typedef CGAL::Cartesian<CGAL::Exact_rational>                   Kernel;
typedef Kernel::Circle_2                                        Circle_2;
typedef Kernel::Segment_2                                       Segment_2;
typedef CGAL::Arr_circle_segment_traits_2<Kernel>         Circle_Segment_traits_2;
typedef std::string                                       Curve_Name;
typedef CGAL::Arr_consolidated_curve_data_traits_2
                   <Circle_Segment_traits_2, Curve_Name>  Traits_2;
typedef Traits_2::Point_2                                 TPoint_2;
typedef Traits_2::Curve_2                                 Curve_2;
typedef Traits_2::CoordNT                                 CoordNT;
typedef CGAL::Arr_face_extended_dcel<Traits_2 , unsigned int>   Dcel ;
typedef CGAL::Arrangement_with_history_2<Traits_2, Dcel>        Arr_with_hist_2;
typedef CGAL::Dual<Arr_with_hist_2>                             Dual_arrangement;
typedef CGAL::Arr_face_index_map<Arr_with_hist_2>               Face_index_map;
