- To:
- Subject: Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?
- Date: Sun, 26 Aug 2018 00:18:59 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi Morteza,
If you really need to convert Arrangement_with_history_2 to Arrangement_2, then you would need to reconstruct Arrangement_2, but conceptually, everything you can do with Arrangement_2 you can also do with Arrangement_with_history_2.
Is it possible that you simply forgot to include the header that contains the definition of CGAL::Dual, namely, <CGAL/graph_traits_Dual_Arrangement_2.h> ?
Anyway, if you still have a problem, please paste a complete minimal program.
Efi
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
Hi, I want to use Dual class to construct a dual graph of my arrangement, but I get the compile error :C2079: 'dual' uses undefined class 'CGAL::Dual<Arr_with_hist_2>'and I think it's for Arrangement_with_history_2 that I use to define the arrangement in the code. Now I need to convert Arr_with_hist_2 to Arrangement_2 and I don't know how to do this?my CGAL type definition :typedef CGAL::Cartesian<CGAL::Exact_rational> Kernel;typedef Kernel::Circle_2 Circle_2;typedef Kernel::Segment_2 Segment_2;typedef CGAL::Arr_circle_segment_traits_2<Kernel> Circle_Segment_traits_2;typedef std::string Curve_Name;typedef CGAL::Arr_consolidated_curve_data_traits_2<Circle_Segment_traits_2, Curve_Name> Traits_2;typedef Traits_2::Point_2 TPoint_2;typedef Traits_2::Curve_2 Curve_2;typedef Traits_2::CoordNT CoordNT;typedef CGAL::Arr_face_extended_dcel<Traits_2 , unsigned int> Dcel ;typedef CGAL::Arrangement_with_history_2<Traits_2, Dcel> Arr_with_hist_2; typedef CGAL::Dual<Arr_with_hist_2> Dual_arrangement; typedef CGAL::Arr_face_index_map<Arr_with_hist_2> Face_index_map;
- [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Morteza Manavi, 08/25/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Efi Fogel, 08/25/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Morteza Manavi, 08/26/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Efi Fogel, 08/26/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Sebastien Loriot (GeometryFactory), 08/28/2018
