- To:
- Subject: Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex
- Date: Mon, 27 Aug 2018 08:42:34 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hi Peter;
Le 26/08/2018 à 13:41, kloffy a écrit :
Hi,
I am trying to get my head around combinatorial maps, and I thought I would
start with the simplest non-trivial example, a 1-simplex (#0-cells=2,
#1-cells=1).
So, first I tried the obvious construction helper:
CGAL::Combinatorial_map<1> cm;
cm.make_edge();
cm.display_characteristics(std::cout);
std::cout << std::endl;
However, this gives me:
#Darts=2, #0-cells=2, #1-cells=2, #ccs=2
But that's not quite right (#1-cells=2).
A 1D combinatorial map can be seen as a set of 1D curves (possibly opened).
As said in the doc of make_edge (here https://doc.cgal.org/latest/Combinatorial_map/classGenericMap.html#a6f455fd64b650495392bddecedbd5afe), this method requires that the dimension of the combinatorial map n is >= 2.
Indeed, an edge is made of two darts linked by beta2 and this requires n>=2.
In a 1D cmap, an edge is made of two darts linked by beta1. If you want to create such an edge by hand, you must use
cm.dart_link_beta<1>(dh1, dh2);
To have an intuition of what is a combinatorial map, have a look at the 2 first figures in the user manual (here https://doc.cgal.org/latest/Combinatorial_map/index.html).
Hope this help.
Best
Guillaume
So I tried creating the 1-simplex manually:
auto dh1 = cm.create_dart();
auto dh2 = cm.create_dart();
#Darts=2, #0-cells=2, #1-cells=2, #ccs=1
But that's still not quite right (#1-cells=2).
I tried a bunch of other things, but I never managed to get the intended
result (#1-cells=1). My intuition for combinatorial maps is still very poor,
which was the motivation for this exercise. At this point, I feel like I
must be missing something. Please forgive me if it is something very
obvious. Still, I would appreciate any hints...
Cheers,
Peter
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
smime.p7s
Description: Signature cryptographique S/MIME
- [cgal-discuss] 1D Combinatorial Map - 1-Simplex, kloffy, 08/26/2018
- Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex, Guillaume Damiand, 08/27/2018
- Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex, Peter Klosowski, 08/27/2018
- Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex, Peter Klosowski, 08/29/2018
- Re:[cgal-discuss] 1D Combinatorial Map - 1-Simplex, xlhu, 08/29/2018
- Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex, Guillaume Damiand, 08/29/2018
- Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex, Peter Klosowski, 08/31/2018
