cgal-discuss - Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex
  • To:
  • Subject: Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex
  • Date: Mon, 27 Aug 2018 17:58:38 +1000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi Guillaume,
Many thanks for your suggestions! However, I am still a bit confused. I tried your code:
    CGAL::Combinatorial_map<1> cm;
    auto dh1 = cm.create_dart();
    auto dh2 = cm.create_dart();
    cm.dart_link_beta<1>(dh1, dh2);
    cm.display_characteristics(std::cout);
    std::cout << std::endl;
But it still gives me:
#Darts=2, #0-cells=2, #1-cells=2, #ccs=1
Am I wrong to expect that an edge would only have a single 1-cell? My expectation comes from the faces of a 1-simplex (https://en.wikipedia.org/wiki/Simplex). Perhaps in combinatorial maps it works differently...
I think the main challenge for me in terms of forming an intuition is to understand the different betas. I can see the value of combinatorial maps to represent cellular structures, and a lot of the concepts and operations make sense. I am just having trouble getting my head around why an edge is made of two darts linked by beta1, as opposed to beta0, for example?
I hope some of that makes sense. Thank you again for the help!
Cheers,
Peter
On Mon, Aug 27, 2018 at 4:43 PM Guillaume Damiand <> wrote:
Hi Peter;
Le 26/08/2018 à 13:41, kloffy a écrit :
> Hi,
> I am trying to get my head around combinatorial maps, and I thought I would
> start with the simplest non-trivial example, a 1-simplex (#0-cells=2,
> #1-cells=1).
> So, first I tried the obvious construction helper:
> cm.make_edge();
> However, this gives me:
> #Darts=2, #0-cells=2, #1-cells=2, #ccs=2
> But that's not quite right (#1-cells=2).
A 1D combinatorial map can be seen as a set of 1D curves (possibly opened).
As said in the doc of make_edge (here
https://doc.cgal.org/latest/Combinatorial_map/classGenericMap.html#a6f455fd64b650495392bddecedbd5afe),
this method requires that the dimension of the combinatorial map n is >= 2.
Indeed, an edge is made of two darts linked by beta2 and this requires n>=2.
In a 1D cmap, an edge is made of two darts linked by beta1. If you want
to create such an edge by hand, you must use
To have an intuition of what is a combinatorial map, have a look at the
2 first figures in the user manual (here
https://doc.cgal.org/latest/Combinatorial_map/index.html).
Hope this help.
Best
Guillaume
> So I tried creating the 1-simplex manually:
> But that's still not quite right (#1-cells=2).
> I tried a bunch of other things, but I never managed to get the intended
> result (#1-cells=1). My intuition for combinatorial maps is still very poor,
> which was the motivation for this exercise. At this point, I feel like I
> must be missing something. Please forgive me if it is something very
> obvious. Still, I would appreciate any hints...
> Cheers,
> Peter
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34                 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
