- To:
- Subject: Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?
- Date: Tue, 28 Aug 2018 10:51:04 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
and here is the link :)
https://github.com/CGAL/cgal/pull/3295
On 08/28/2018 10:39 AM, Sebastien Loriot (GeometryFactory) wrote:
Could you try if the patch from this PR solves your issue?
Thanks,
Sebastien.
On 08/26/2018 02:26 PM, Morteza Manavi wrote:
I attach a small program that reproduces the compilation error.
Please look at the " graph_traits_Dual_Arrangement_2.h " file, you will find that the CGAL::Arrangement_2 is used for calculations.
Maybe error is for that?
On Sun, Aug 26, 2018 at 4:23 PM Efi Fogel < <mailto:>> wrote:
Please attach a small program that reproduces the compilation error.
I was, by the way, able to compile the lines of code you have posted
after adding the appropriate include statements.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
On Sun, 26 Aug 2018 at 14:37, Morteza Manavi
<mailto:>>
wrote:
I looked, the header file was included.
On Sun, Aug 26, 2018 at 3:57 PM Efi Fogel
<mailto:>>
wrote:
Is it possible that you simply forgot to include the header
that contains the definition of CGAL::Dual, namely,
<CGAL/graph_traits_Dual_Arrangement_2.h> ?
____ _ ____ _
_/
On Sun, 26 Aug 2018 at 14:19, Morteza Manavi
< <mailto:>> wrote:
Exactly, compiler give error:
C2079: 'dual' uses undefined class
'CGAL::Dual<Arr_with_hist_2>'
C2440: 'initializing': cannot convert from
'Arr_with_hist_2' to 'int'
in line :
Dual_arrangement dual(arr);
of my code.
(Notice that the error is not occur at runtime)
On Sun, Aug 26, 2018 at 2:47 PM Efi Fogel
<mailto:>>
wrote:
What makes you think that the Dual class does not
accept Arrangement_with_history_2?
____ _ ____ _
_/
On Sun, 26 Aug 2018 at 12:15, Morteza Manavi
<mailto:>>
wrote:
Thank you Efi,
But I don't want to delete CGAL::Dual because I
need to construct a dual graph representation of
the arrangement, and on the other hand I need to
have curve handler that it's possible with use
of Arrangement_with_history_2 class.
Apparently the Dual class does not accept
Arrangement_with_history_2 as input and
according to your answer I can't directly
Arrangement_2. I think, I must write my own dual
graph class that accept
Arrangement_with_history_2 as input.
Morteza.
On Sun, Aug 26, 2018 at 1:50 AM Efi Fogel
<mailto:>>
wrote:
Hi Morteza,
If you really need to convert
Arrangement_with_history_2 to Arrangement_2,
then you would need to reconstruct
Arrangement_2, but conceptually, everything
you can do with Arrangement_2 you can also
do with Arrangement_with_history_2.
include the header that contains the
Anyway, if you still have a problem, please
paste a complete minimal program.
Efi
____ _ ____ _
_/
On Sat, 25 Aug 2018 at 16:00, Morteza Manavi
<mailto:>>
wrote:
Hi, I want to use Dual class to
construct a dual graph of my
arrangement, but I get the compile error :
and I think it's for
Arrangement_with_history_2 that I use to
define the arrangement in the code. Now
I need to convert Arr_with_hist_2 to
Arrangement_2 and I don't know how to do
this?
my CGAL type definition :
typedefCGAL::Cartesian<CGAL::Exact_rational>Kernel;
typedefKernel::Circle_2Circle_2;
typedefKernel::Segment_2Segment_2;
typedefCGAL::Arr_circle_segment_traits_2<Kernel>Circle_Segment_traits_2;
typedefstd::stringCurve_Name;
typedefCGAL::Arr_consolidated_curve_data_traits_2
<Circle_Segment_traits_2,Curve_Name>Traits_2;
typedefTraits_2::Point_2TPoint_2;
typedefTraits_2::Curve_2Curve_2;
typedefTraits_2::CoordNTCoordNT;
typedefCGAL::Arr_face_extended_dcel<Traits_2,unsignedint>Dcel;
typedefCGAL::Arrangement_with_history_2<Traits_2,Dcel>Arr_with_hist_2;
typedefCGAL::Dual<Arr_with_hist_2>Dual_arrangement;
typedefCGAL::Arr_face_index_map<Arr_with_hist_2>Face_index_map;
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, (continued)
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Efi Fogel, 08/25/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Morteza Manavi, 08/26/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Efi Fogel, 08/26/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Sebastien Loriot (GeometryFactory), 08/28/2018
- Re: [cgal-discuss] How to convert Arrangement_with_history_2 to Arrangement_2?, Morteza Manavi, 08/28/2018
