cgal-discuss - Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • To:
  • Subject: Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • Date: Wed, 24 Oct 2018 07:24:21 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
Do you have all the needed dependencies? Boost IO Streams, Boost Serialization? (+ LASlib if you want to open LiDAR files)
Can you show the output of the cmake command?
Best regards,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 24/10/2018 à 06:20, Andy Li a écrit :
Hi, I am testing the point set classification function include manual extraction of the training set in CGAL 4.13. Unfortunately, after compiling the whole project, the Polyhedron_3.exe just can load the four implicit functions and four IO file functions. Though I put the .dlls into the same document of .exe and load the plugins from the program interface, they also do not work. What's wrong with my compile? Best regard Andy Li
