cgal-discuss - Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • To:
  • Subject: Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • Date: Wed, 24 Oct 2018 02:00:43 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
When I use cmd to run the demo with the option "--verbose", it shows that
"###looking for ****.dll" and "###loading ****.dll". After that, the problem
is still here. The DLLs isn't loaded by the demo exe...
Sorry, I just could copy part of them, as follow:(The first line may show
that "Enable Scrift"?)
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Surface_mesh/Releas
e/mesh_simplification_sm_plugin.dll "...
### Loading "
e/offset_meshing_plugin.dll "...
### Loading "
e/parameterization_plugin.dll "...
### Loading "
e/parameterization_sm_plugin.dll "...
### Loading "
e/shortest_path_plugin.dll "...
### Loading "
e/shortest_path_sm_plugin.dll "...
# Looking for plugins in directory
"C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugi
ns/Surface_mesh_deformation/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Surface_mesh_deform
ation/Release/edit_polyhedron_plugin.dll "...
### Loading "
ation/Release/edit_sm_plugin.dll "...
Using context 4 . 2 GL
GL WARNING : (ShaderCompilerSource : OtherType)
GLSL compile warning(s) for shader 1, "": WARNING: -1:65535: '#version' :
vers
ion number deprecated in OGL 3.0 forward compatible context driver
GLSL compile warning(s) for shader 2, "": WARNING: -1:65535: '#version' :
vers
GLSL compile warning(s) for shader 4, "": WARNING: -1:65535: '#version' :
vers
GLSL compile warning(s) for shader 5, "": WARNING: -1:65535: '#version' :
vers
GLSL compile warning(s) for shader 7, "": WARNING: -1:65535: '#version' :
vers
WARNING: 0:11: Only GLSL version > 110 allows postfix "F" or "f" for float
GLSL compile warning(s) for shader 8, "": WARNING: -1:65535: '#version' :
vers
WARNING: 0:6: Only GLSL version > 110 allows postfix "F" or "f" for float
WARNING: 0:7: Only GLSL version > 110 allows postfix "F" or "f" for float
WARNING: 0:8: Only GLSL version > 110 allows postfix "F" or "f" for float
GL ERROR : (ShaderCompilerSource : ErrorType)
GLSL compile failed for shader 10, "": WARNING: -1:65535: '#version' :
version
ERROR: 0:1: '' : syntax error: #version is mandatory and should be set
before an
y other token
ERROR: 0:2: '' : syntax error: #version is mandatory and should be set
before an
y other token
ERROR: 0:? : 'pre-mature EOF' : syntax error syntax error
QOpenGLShader::compile(Vertex): WARNING: -1:65535: '#version' : version
number
before an
y other token
before an
y other token
*** Problematic Vertex shader source code ***
#define lowp
#define mediump
#define highp
#line 1
void setPosition();
void main(void)
setPosition();
attribute highp vec2 vertexCoordsArray;
attribute highp vec3 pmvMatrix1;
attribute highp vec3 pmvMatrix2;
attribute highp vec3 pmvMatrix3;
void setPosition(void)
highp mat3 pmvMatrix = mat3(pmvMatrix1, pmvMatrix2, pmvMatrix3);
vec3 transformedPos = pmvMatrix * vec3(vertexCoordsArray.xy, 1.0);
gl_Position = vec4(transformedPos.xy, 0.0, transformedPos.z);
Vertex shader for simpleShaderProg (MainVertexShader &
PositionOnlyVertexShader)
failed to compile
GLSL compile failed for shader 11, "": WARNING: -1:65535: '#version' :
version
before an
y other token
before an
y other token
QOpenGLShader::compile(Fragment): WARNING: -1:65535: '#version' : version
numbe
before an
y other token
before an
y other token
*** Problematic Fragment shader source code ***
#define lowp
#define mediump
#define highp
#line 1
lowp vec4 srcPixel();
void main()
gl_FragColor = srcPixel();
return vec4(0.98, 0.06, 0.75, 1.0);
Fragment shader for simpleShaderProg (MainFragmentShader &
ShockingPinkSrcFragme
ntShader) failed to compile
GLSL link failed for program 12, "": Attached vertex shader is not
compiled.
GLSL link failed: Attached vertex shader is not compiled.
QOpenGLShader::link: Attached vertex shader is not compiled.
Errors linking simple shader: Attached vertex shader is not compiled.
GLSL compile failed for shader 13, "": WARNING: -1:65535: '#version' :
version
before an
y other token
before an
y other token
number
before an
y other token
before an
y other token
#define lowp
#define mediump
#define highp
#line 1
attribute highp vec2 textureCoordArray;
varying highp vec2 textureCoords;
void setPosition();
void main(void)
setPosition();
textureCoords = textureCoordArray;
attribute highp vec4 vertexCoordsArray;
gl_Position = vertexCoordsArray;
Vertex shader for blitShaderProg (MainWithTexCoordsVertexShader &
UntransformedP
ositionVertexShader) failed to compile
GLSL compile failed for shader 14, "": WARNING: -1:65535: '#version' :
version
before an
y other token
before an
y other token
numbe
before an
y other token
before an
y other token
#define lowp
#define mediump
#define highp
#line 1
void main()
uniform sampler2D imageTexture;
return texture2D(imageTexture, textureCoords);
Fragment shader for blitShaderProg (MainFragmentShader &
ImageSrcFragmentShader)
failed to compile
GLSL link failed for program 15, "": Attached fragment shader is not
compiled.
GLSL link failed: Attached fragment shader is not compiled.
QOpenGLShader::link: Attached fragment shader is not compiled.
Errors linking blit shader: Attached fragment shader is not compiled.
GLSL compile warning(s) for shader 16, "": WARNING: -1:65535: '#version' :
ver
sion number deprecated in OGL 3.0 forward compatible context driver
GLSL compile warning(s) for shader 17, "": WARNING: -1:65535: '#version' :
ver
Execution of script ":/cgal/Polyhedron_3/javascript/lib.js"
Duplicate Filter: "camera_positions_plugin"
This filter will not be available.
Duplicate Filter: "polylines_io_plugin"
GLSL compile warning(s) for shader 23, "": WARNING: -1:65535: '#version' :
ver
GLSL compile warning(s) for shader 24, "": WARNING: -1:65535: '#version' :
ver
