cgal-discuss - Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • To:
  • Subject: Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • Date: Wed, 24 Oct 2018 07:32:31 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
What kind of file are you trying to load?
Sebastien.
On 10/24/2018 07:29 AM, Andy Li wrote:
Except for Laslib and Metis, I think I take rest of the dependences. The
cmake command is as follow:
Boost version: 1.62.0
Found the following Boost libraries:
thread
system
chrono
date_time
atomic
Boost include dirs: C:/boost_1_62_0/include
Boost libraries:
optimized;C:/boost_1_62_0/lib64-msvc-12.0/boost_thread-vc120-mt-1_62.lib;debug;C:/boost_1_62_0/lib64-msvc-12.0/boost_thread-vc120-mt-gd-1_62.lib;optimized;C:/boost_1_62_0/lib64-msvc-12.0/boost_system-vc120-mt-1_62.lib;debug;C:/boost_1_62_0/lib64-msvc-12.0/boost_system-vc120-mt-gd-1_62.lib;optimized;C:/boost_1_62_0/lib64-msvc-12.0/boost_chrono-vc120-mt-1_62.lib;debug;C:/boost_1_62_0/lib64-msvc-12.0/boost_chrono-vc120-mt-gd-1_62.lib;optimized;C:/boost_1_62_0/lib64-msvc-12.0/boost_date_time-vc120-mt-1_62.lib;debug;C:/boost_1_62_0/lib64-msvc-12.0/boost_date_time-vc120-mt-gd-1_62.lib;optimized;C:/boost_1_62_0/lib64-msvc-12.0/boost_atomic-vc120-mt-1_62.lib;debug;C:/boost_1_62_0/lib64-msvc-12.0/boost_atomic-vc120-mt-gd-1_62.lib
Visual Leak Detector (VLD) is not found.
Multi-configuration CMake generator: cannot display flags
Targetting Visual Studio 12 2013 Win64
Target build enviroment supports auto-linking
Using VC12 compiler.
Generator uses intermediate configuration directory: $(Configuration)
Requested component: Qt5
Requested component: ImageIO
Requested component: MPFR
Requested component: GMP
Can not locate METIS include directory
Can not locate METIS library
Could NOT find METIS (missing: METIS_LIBRARIES METIS_INCLUDE_DIRS)
Found Intel TBB
Found Intel TBB
thread
system
filesystem
chrono
date_time
atomic
serialization
iostreams
regex
bzip2
zlib
Found OpenCV 2.4.13
NOTICE : the LAS IO plugin needs LAS libraries and will not be compiled.
NOTICE : the Partition plugin needs METIS libraries and will not be
compiled.
Configuring done
