cgal-discuss - Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • To:
  • Subject: Re: [cgal-discuss] Compile CGAL 4.13 Polyhedron_Demo
  • Date: Wed, 24 Oct 2018 02:09:54 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
The former part is shown as follow.
Enable scripts.
# Looking for plugins in directory
"C:/dev/CGAL-4.13/demo/Polyhedron/build/Relea
se"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/affine_transform_pl
ugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/affine_transform_sm
_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/alpha_shape_plugin.
dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/basic_generator_plu
gin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/c3t3_io_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/c3t3_rib_exporter_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/camera_positions_pl
ugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/classification_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/clip_polyhedron_plu
gin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/clipping_box_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/convex_hull_plugin.
dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/corefinement_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/create_bbox_mesh_pl
ugin.dll "...
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/cut_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/degenerated_faces_p
oly_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/degenerated_faces_s
m_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/detect_sharp_edges_
plugin.dll "...
### Loading "
sm_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/display_property_pl
ugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/distance_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/distance_sm_plugin.
dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/edit_box_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/edit_polyhedron_plu
gin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/edit_sm_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/extrude_poly_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/extrude_sm_plugin.d
ll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/fairing_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/fairing_sm_plugin.d
ll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/features_detection_
plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/gocad_plugin.dll ".
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/hole_filling_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/hole_filling_polyli
ne_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/hole_filling_sm_plu
gin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/inside_out_plugin.d
ll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/io_image_plugin.dll
+ Loading Function "classification_plugin.dll"...
+ Loading Function "p_klein_function_plugin.dll"...
+ Loading Function "p_sphere_function_plugin.dll"...
+ Loading Function "p_tanglecube_function_plugin.dll"...
+ Loading Function "ply_plugin.dll"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/io_implicit_functio
n_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/isotropic_remeshing
_plugin.dll "...
### Loading "
_sm_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/jet_fitting_plugin.
dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/join_and_split_poly
hedra_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/join_and_split_sm_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/kernel_plugin.dll "
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mean_curvature_flow
_skeleton_plugin.dll "...
### Loading "
_skeleton_sm_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/merge_point_sets_pl
ugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mesh_2_plugin.dll "
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mesh_3_optimization
_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mesh_3_plugin.dll "
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mesh_plane_detectio
n_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mesh_segmentation_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/mesh_simplification
_plugin.dll "...
### Loading "
_sm_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/nef_io_plugin.dll "
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/nef_plugin.dll
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/off_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/off_to_nef_plugin.d
ll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/offset_meshing_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/orient_soup_plugin.
dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/parameterization_pl
ugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/parameterization_sm
_plugin.dll "...
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/pca_plugin.dll
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/ply_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_inside_polyhe
dron_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_average_s
pacing_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_bilateral
_smoothing_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_from_vert
ices_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_interfere
nce_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_normal_es
timation_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_outliers_
removal_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_selection
_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_shape_det
ection_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_simplific
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_smoothing
_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_to_mesh_d
istance_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_upsamplin
g_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/point_set_wlop_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/polyhedron_slicer_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/polyhedron_stitchin
g_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/polylines_io_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/random_perturbation
_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/repair_polyhedron_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/selection_io_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/selection_io_sm_plu
gin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/selection_plugin.dl
l "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/selection_sm_plugin
.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/self_intersection_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/self_intersection_s
m_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/shortest_path_plugi
n.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/shortest_path_sm_pl
ugin.dll "...
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/stl_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/subdivision_methods
_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/surf_io_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/surface_intersectio
n_plugin.dll "...
### Loading "
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/surface_mesh_io_plu
gin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/surface_mesh_to_pol
yhedron_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/surface_reconstruct
ion_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/triangulate_facets_
plugin.dll "...
### Loading " C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/vtk_plugin.dll
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Release/vtk_sm_plugin.dll "
"C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugi
ns"...
se"...
ns/AABB_tree/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/AABB_tree/Release/c
ut_plugin.dll "...
ns/Camera_position/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Camera_position/Rel
ease/camera_positions_plugin.dll "...
ns/Classification/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Classification/Rele
ase/classification_plugin.dll "...
ns/Convex_decomposition/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Convex_decompositio
n/Release/nef_plugin.dll "...
ns/Convex_hull/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Convex_hull/Release
/convex_hull_plugin.dll "...
### Loading "
/kernel_plugin.dll "...
ns/Display/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Display/Release/dis
play_property_plugin.dll "...
ns/IO/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/gocad_pl
ugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/io_impli
cit_function_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/nef_io_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/off_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/off_to_n
ef_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/ply_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/polyline
s_io_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/selectio
n_io_plugin.dll "...
### Loading "
n_io_sm_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/stl_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/surf_io_
plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/surface_
mesh_io_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/vtk_plug
in.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/vtk_sm_p
lugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/IO/Release/xyz_plug
in.dll "...
ns/Mesh_2/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Mesh_2/Release/mesh
_2_plugin.dll "...
ns/Mesh_3/Release"...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Mesh_3/Release/c3t3
_io_plugin.dll "...
### Loading "
_rib_exporter_plugin.dll "...
### Loading "
C:/dev/CGAL-4.13/demo/Polyhedron/build/Plugins/Mesh_3/Release/io_i
mage_plugin.dll "...
