cgal-discuss - Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2
  • To:
  • Subject: Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2
  • Date: Wed, 7 Nov 2018 06:03:12 -0600 (CST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Thank you for quick replay Sebastien.
Strange. I can reproduce it every time. Have you used exactly the same
templates as I am? Also triangulation points and constraints are 3D points.
Could it be the issue if I'm inserting constraint aligned with vertices and
edges?
Yes I'm using Exact_predicates_tag itag.
I will make example but I thought that maybe my problem is trivial so wanted
to check first. I will need a little time to create example.
Thank you,
Marin
