cgal-discuss - Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2
  • To:
  • Subject: Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2
  • Date: Fri, 9 Nov 2018 07:21:59 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:IqTVoxQrIxlXu6J/O4mIXSeh1Npsv+yvbD5Q0YIujvd0So/mwa6yYh2N2/xhgRfzUJnB7Loc0qyK6/+mATRIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfbF/IA+qoQnNq8IbnZZsJqEtxxXTv3BGYf5WxWRmJVKSmxbz+MK994N9/ipTpvws6ddOXb31cKokQ7NYCi8mM30u683wqRbDVwqP6WACXWgQjxFFHhLK7BD+Xpf2ryv6qu9w0zSUMMHqUbw5Xymp4qF2QxHqlSgHLSY0/nzJhMx+jKxVoxyvqBJwzIHWfI6bO+Fzfr/fcN4AWWZNQshcWi5HD4ihb4UPFe0BPeNAooXzulUBswCxChO3BOPzyz9HmHn21rA83eQmCwHG3QsgH84Tu3jQrdv6KqASUeWrw6nU1zXCb/NY1i3h54jUdRAhu/GNUbd+fcHMzkQvDAfFjlKKqYzkODOVyv4Bs22f7+d7WuKvjnQoqwB1ojS12sgsjYzJi5sTx1vZ+yt5x4M1Kse5SE59edOkFoFfuDqBOItyXMwuWX1nuCE/yrEetp67fTQKyJQ6xxHEcfCIb4+I4hflWe2MIjl4nGpodKyjixu260Stye3xWtOp3FpUrSdJiNbBu38V2xHQ9sSLUOVx8lqh1DqV1A3f9vtILV00mKfULZMq36Q+mYAJsUvZGy/7gEX2g7GSdkUj4uWo7v7oYrTippOFOY50jxzyPr0gmsGwDuk0KAcOX2+c+eSz0L3s41f1T6lNjv0ziqXZsZbaKtoHpqOhHQNZzoIu5wy8AjqmytgUgGcLIVFfdB+IgIXlI1TOL+r5Dfe7jVSsijBrx/XeM736BpXNKWLDkLbmfbZh8UJczQ4zwMtQ55JREL4BIfbzVlXtu9zfCx81Kxa0zPr/CNVhyoMeXnqCDbOWMKzItV+E//8gI+iXZIAJpTb9MOMl6uX1jX45nF8dZbOm0YEWaHC+BPRmIl+WbWDigtcbQi82uV81Q+XuzVGDSjVOfG2aXqQm5zh9Bpj1I53EQ9Xnu7GL1TynH5BQLkRBEFGLDT+oWIiDXvoQcjO8K8R9lSYVFPLpH5Ql0guvsxO8zr5PIe/d+ylevpXmgosmr9bPnA0/oGQnR/+W1HuAGjktzzE4AgQu1aU6mnRTj1KK0Kx2mftdTIUB6PZAUwN8PpnZnbUjV4LCHznZd9LMc26IB828CGhoHN00yt4KJU16Hof6102R72+RG7YQ0oezKtk0/6bbhSWjIs98zzPZ0fBkgQV6BMRIMmKii+h08A2BX4M=
Hi,
I can reproduce the issue.
I opened a ticket here:
https://github.com/CGAL/cgal/issues/3447
It has to do with the insertion of polylines in a CDT+.
We will update the issue when the bug is fixed.
Thanks for the report,
Sebastien.
On 11/08/2018 02:21 PM, marin wrote:
Hello,
I've made sample that shows exception I get.
Here is full Visual studio solution along with example.xyz points file.
cgal_constraints.7z
<http://cgal-discuss.949826.n4.nabble.com/file/t376044/cgal_constraints.7z>
This is main function:
When calling dt.insert_constraint second time I'm getting exception in CGAL.
Thank you very much!
Marin
