- To:
- Subject: Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2
- Date: Wed, 7 Nov 2018 13:27:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 11/07/2018 01:03 PM, marin wrote:
points.
Thank you for quick replay Sebastien.
Strange. I can reproduce it every time. Have you used exactly the same > templates as I am? Also triangulation points and constraints are 3D
I used the same types but for the traits but it shouldn't be an issue.
Sebastien.
Could it be the issue if I'm inserting constraint aligned with vertices and
edges? >
Yes I'm using Exact_predicates_tag itag.
I will make example but I thought that maybe my problem is trivial so wanted
to check first. I will need a little time to create example.
Thank you,
Marin
- [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2, marin, 11/07/2018
- Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2, Sebastien Loriot (GeometryFactory), 11/07/2018
- Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2, marin, 11/07/2018
- Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2, marin, 11/08/2018
- Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2, Sebastien Loriot (GeometryFactory), 11/09/2018
- Re: [cgal-discuss] Inserting constraints in Constrained_triangulation_plus_2, marin, 11/09/2018
