cgal-discuss - Re: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?
  • To:
  • Subject: Re: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?
  • Date: Mon, 25 Feb 2019 17:01:24 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23: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
On Monday, February 25, 2019 11:13:01 AM CET YB wrote:
> Thank you Laurent.
> Do I get the simplified idea of CGAL's meshing procedure correctly?
> 1. Our oracle gives us some points in the isosurface
> 2. A restricted Delaunay triangulation is computed for these points and
> gives us already a good approximation
> 3. In the resulting triangulation skinny triangles below some limit are
> eliminated by applying Delaunay refinement
Yes. That's roughly that. Here is brief summary of the algo
https://www-sop.inria.fr/geometrica/software/cgalmesh/restrictedDT.html
Laurent Rineau, PhD
