Re: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?
- To:
- Subject: Re: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?
- Date: Mon, 25 Feb 2019 17:35:11 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Perfect. Thank you for the brief summary. It helps a lot for my
understanding.
On 25.02.2019 17:01, Laurent Rineau (CGAL/GeometryFactory) wrote:
> On Monday, February 25, 2019 11:13:01 AM CET YB wrote:
>> Thank you Laurent.
>> Do I get the simplified idea of CGAL's meshing procedure correctly?
>> 1. Our oracle gives us some points in the isosurface
>> 2. A restricted Delaunay triangulation is computed for these points and
>> gives us already a good approximation
>> 3. In the resulting triangulation skinny triangles below some limit are
>> eliminated by applying Delaunay refinement
> Yes. That's roughly that. Here is brief summary of the algo
> https://www-sop.inria.fr/geometrica/software/cgalmesh/restrictedDT.html
- [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?, yellowbed, 02/23/2019
- Re: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?, Laurent Rineau (CGAL/GeometryFactory), 02/25/2019
- Re: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?, YB, 02/25/2019
