cgal-discuss - Re: [cgal-discuss] I cannot run the straight skeleton example
  • To:
  • Subject: Re: [cgal-discuss] I cannot run the straight skeleton example
  • Date: Wed, 15 May 2019 15:15:27 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Sorry, since I saw new_scalar.cpp I thought this was an example you wrote.
So you're saying that running Create_straight_skeleton_2.cpp fails on your machine? Anything specific about your config? We have several
windows platform in our testsuite where this example runs fine
https://cgal.geometryfactory.com/CGAL/testsuite/
Are you using Visual Leak Detector?
Sebastien.
On 5/10/19 1:05 PM, jpmaterial wrote:
Hi,
the example is self-contained, it does not ask for input. Taking the
Create_offset_polygons_2 project, the polygon used in the main file
(Create_offset_polygons_2.cpp) is the one I posted below.
Best regards,
Jann
poly.push_back( Point(-1,-1) ) ;
poly.push_back( Point(0,-12) ) ;
poly.push_back( Point(1,-1) ) ;
poly.push_back( Point(12,0) ) ;
poly.push_back( Point(1,1) ) ;
poly.push_back( Point(0,12) ) ;
poly.push_back( Point(-1,1) ) ;
poly.push_back( Point(-12,0) ) ;
