cgal-discuss - Re: [cgal-discuss] I cannot run the straight skeleton example
  • To:
  • Subject: Re: [cgal-discuss] I cannot run the straight skeleton example
  • Date: Thu, 16 May 2019 05:05:02 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
"Anything specific about your config?" is a pretty broad question. I'm sure
my set of installed program is unique, as is every CGAL developer's :)
The CGAL dependencies (Qt, CMake, boost) I mostly just installed to run
CGAL. The Visual Studio I've had for longer but hardly started and not
modified.
I don't think a memory is the problem here. The program fails within seconds
of starting, on a calculation of only an octagon with GB of memory being
free. The root cause must be something else.
