cgal-discuss - Re: [cgal-discuss] Cannot read my data file in off format
  • To:
  • Subject: Re: [cgal-discuss] Cannot read my data file in off format
  • Date: Thu, 12 Sep 2019 21:01:56 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:CN3IphfSixF7TksdvJ5C0SX8lGMj4u6mDksu8pMizoh2WeGdxcW8Yx7h7PlgxGXEQZ/co6odzbaP6Oa4BCdZus7J8ChbNsAVDVld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbdgMutyu+95YDYbRlWizqhe7NyKwi9oRnMusUMjoZuN6g8xgHVrnZIdOha2G1lKU6OlBr4+su84YRv/itNt/4/7cJMTbn2c6ElRrFEEToqNHw46tf2vhfZVwuP4XUcUmQSkhVWBgXO8Q/3UJTsvCbkr+RxwCaVM9H4QrAyQjSi8rxkSAT0hycdNj4263/Yh8pth69Guh2hphh/w4nJYIGJMfd1Y63Qcc8GSWdHQ81cUTFKDIGhYIsVF+cPIPhWr4f9qVUNoxWxCwajC+HzxTFHnXL2wa833v49HQ3a0gEtHdQDu2nUotXvM6cSVPi4wKfVwzrddPxZwyz96JTJch8/p/GHQLR+cc3LyUkuEAPFkkibpYjkMTyL0eQNtnaU7/Z6VeOvi2AosR1+oiSoxsc2iojFg4wZwU3D+CVixIY1Ise4SE98Yd64CpdQsiWaOpB5QsMnWW5ouSI6xqcatp68eSgH0ZIqzAPRZfyAdoiH+BPjVOCJLDd+nn1qY6mwhxKs/kS61uL8Ucy03E5FripEjtnMtm0N2AfJ5sebTft9+0Gs0iuM2QDL8uxIP1w4mK7BJ5MiwrM8jIcfvVrAEyPsmEj6kLeaels+9eS09ujqZ6vpq5GTOoJxlA7+PKUjldC6DOglPQUBRHSX9OG+2bL/40H2WrBHg/4tnabFrp/XINkUq6y4DgJW14ss8BKyAjSo3dkegHIJNkhKeAidgIjsI1zOIO73DfO4g1m0lTdk3fHGPrn4DpTDK3jPja7tfbh95kJA0gYzwtdf55VbCrEFPv3/QFP+tNvdDhMhMgy0xfjoCMll248ARW6CBrWVPaDSvFOS++4jPeqBaJUVtTrhM/Ql4uThjX49mV8TZ6mp2p4XZWijHvRiJEWZe3vsgtAdEWsQuwo+SPfniFKHUTFJZnayW7gw6S08CIKjFYvDXJyigKSd3CenGZ1bfnxJCl+WHnfsbomLRvYMaDmOLc98iTwETqOsS5Qh1BGrrA/10aBrLuvS+i0CtJLszsJ55+PJlUJ6yTshBMuU1ySBTnp/g3gTbz4wxqF250JnmXmZ1q0tycdVH9VI+/JEVE8eMoTdyPAyS///XQfMYs2YZl+tXtK8EHB7BoYqx9gUYkFhXdCmph/G1iuuRbQSkurYV9QP7qvA0i2pdI5GwHHc2fx51gh0co50LWSjw5VH2U3WDo/NnV+ekv/zJ6sZ1S/JsmyEyDjX5RwKYEtLSazAGEsnSA7WoND+vB6QSravDfE4N1IEx5PabKRNbdLtgBNNQ/KxYI2CMVL0oH+5AFOz/p3JdJDjIjxP0yDUCUxCmAcWry6L
What are you using precisely?
CGAL::Polygon_mesh_processing::reverse_face_orientations()?
How is the mesh read? You should post your code on gist.github.com
and the data set there, it would be easier to help you.
Sebastien.
On 9/12/19 5:48 PM, Shrabani Ghosh wrote:
HI,
I was able to use my surface mesh by changing the orientation. But now I
have a surface mesh which is a bigger one, and when I am trying to change
the orientation, I am not able to do that. After some time, it showing
segmentation fault. How to solve this problem?
