- To:
- Subject: Re: [cgal-discuss] Cannot read my data file in off format
- Date: Fri, 13 Sep 2019 11:19:36 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I am getting something like this from the debugger.
Breakpoint 1, main (argc=1, argv=0x7fffffffd818)
at
/home/sghos003/cgal_examples/orient_polygon_soup/orient_polygon_soup_example.cpp:35
35 CGAL::Polygon_mesh_processing::orient_to_bound_a_volume(mesh);
(gdb) n
Program received signal SIGSEGV, Segmentation fault.
0x000000000058edf0 in
CGAL::HalfedgeDS_halfedge_base<CGAL::HalfedgeDS_list_types<CGAL::Epick,
CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_with_id_3>,
std::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Boolean_tag<true>,
CGAL::Boolean_tag<true> >::face (this=0x0)
at
/home/sghos003/CGAL-4.13.1/include/CGAL/HalfedgeDS_halfedge_base.h:328
328 Face_handle face()
Thanks
Shrabani
- Re: [cgal-discuss] Cannot read my data file in off format, Shrabani Ghosh, 09/12/2019
- Re: [cgal-discuss] Cannot read my data file in off format, Sebastien Loriot (GeometryFactory), 09/12/2019
- Re: [cgal-discuss] Cannot read my data file in off format, Shrabani Ghosh, 09/13/2019
